Obieezx11 0 #1 Posted November 2, 2017 Please help problem clutch toro wheel horse, 1991 model with the belt off, my motor running can hold the blades pully and it stops spinning but with the motor running no belt on the clutch, I turn the blades on and the motor stalls. whats wrong with it guys i love the old thing will bare metal every nut and bolt restore but for now it's my only means of mowing my lawn I was in a bad car accident and suffered greatly so its kind of urgent I find out whats wrong with it as I cant push a mower anymore. PLEASE, ANYONE, CAN I FIX IT CHEAP. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,051 #2 Posted November 2, 2017 With the pto ON the seat switch controls the ignition on most models. Check the wiring to the seat switch and make sure the operator's weight in the seat is actuating the switch. Hard to be on both sides of the seat at the same time. May need help to check that part. The idea behind it is if the operator falls out of the seat with the pto/mower running the engine will quit. If that is not the problem post the model number and serial number so we can find a wiring diagram. 33 different models in 1991. Garry 4 1 Share this post Link to post Share on other sites
TDF5G 2,073 #3 Posted November 2, 2017 I agree, the seat switch would be the first thing to check IMO. Share this post Link to post Share on other sites
Obieezx11 0 #4 Posted November 4, 2017 On 02/11/2017 at 8:00 PM, gwest_ca said: With the pto ON the seat switch controls the ignition on most models. Check the wiring to the seat switch and make sure the operator's weight in the seat is actuating the switch. Hard to be on both sides of the seat at the same time. May need help to check that part. The idea behind it is if the operator falls out of the seat with the pto/mower running the engine will quit. If that is not the problem post the model number and serial number so we can find a wiring diagram. 33 different models in 1991. Garry ok thanks Share this post Link to post Share on other sites
