Wheelie horse 90 #1 Posted October 30, 2017 (edited) After an hour of figuring the cab out in the garage I got it all put together and on the 416 and it's very nice, seems to get pretty warm inside as well. Winter will be the true test of that though Edited October 30, 2017 by Wheelie horse 9 1 Share this post Link to post Share on other sites
Ed Kennell 47,089 #2 Posted October 30, 2017 Looks great, you will enjoy blowing snow in a nice warm cab. Looks like that rear cylinder will pump some heat into the cab. Share this post Link to post Share on other sites
Wishin4a416 2,609 #3 Posted October 30, 2017 (edited) Looks good . Definitely a plus in wet windy weather. I actually have to open the door once in awhile to cool it off. I have a flexible dryer pipe coming off of the cylinder block fins near the exhaust valve area for heat. Kohler 16 model. Nice and toasty. You will like it. Edited October 30, 2017 by Wishin4a416 3 Share this post Link to post Share on other sites
pgiro 38 #4 Posted November 1, 2017 Does the installation of the cab require drilling into the sheet metal at all? Share this post Link to post Share on other sites
shallowwatersailor 3,222 #5 Posted November 1, 2017 (edited) 1 hour ago, pgiro said: Does the installation of the cab require drilling into the sheet metal at all? No, it uses the existing bolts for the fender, and clamps to the footboards. On a 5xi it also uses the screws for the hood larch as well. Here is a set of installation instructions. https://www.originalcab.com/assets/images/10280ToroHT.pdf Edited November 1, 2017 by shallowwatersailor Share this post Link to post Share on other sites
Wheelie horse 90 #6 Posted November 2, 2017 18 hours ago, pgiro said: Does the installation of the cab require drilling into the sheet metal at all? Yes I had to drill two small holes in the foot pans but there not noticeable 16 hours ago, shallowwatersailor said: No, it uses the existing bolts for the fender, and clamps to the footboards. On a 5xi it also uses the screws for the hood larch as well. Here is a set of installation instructions. https://www.originalcab.com/assets/images/10280ToroHT.pdf Yes you can also clamp it Share this post Link to post Share on other sites
MalMac 1,337 #7 Posted November 5, 2017 Word of warning, the flap over the hood will actually wear and scuff the paint. Especially when it gets cold. The vinyl will become real abrasive. Also the zippers on the flap will scratch up the hood decals. Using “Mothers Back to Black” helps keep the vinyl soft and ply able when it gets cold and does not attract dust. 1 Share this post Link to post Share on other sites
Ed Kennell 47,089 #8 Posted November 5, 2017 4 hours ago, MalMac said: Word of warning, the flap over the hood will actually wear and scuff the paint. Especially when it gets cold. The vinyl will become real abrasive. Also the zippers on the flap will scratch up the hood decals. Using “Mothers Back to Black” helps keep the vinyl soft and ply able when it gets cold and does not attract dust. I attach a strip of rubber with magnets to protect this area where the cab rubs the hood. 5 Share this post Link to post Share on other sites
Big papi 9 #9 Posted November 17, 2017 I’m sorry maybe someone asked. But where did you get it? Share this post Link to post Share on other sites
953 nut 68,732 #10 Posted November 17, 2017 3 hours ago, Big papi said: I’m sorry maybe someone asked. But where did you get it? Check out the web site. You may be able to find a used one in the spring. https://www.originalcab.com/Original-Tractor-Cab-Toro-Hard-Top-Cab.html 1 Share this post Link to post Share on other sites
Wheelie horse 90 #11 Posted November 17, 2017 5 hours ago, Big papi said: I’m sorry maybe someone asked. But where did you get it? I actually found this one on creigs list I've been looking for a while and just happen to find this one 1 Share this post Link to post Share on other sites
Ed Kennell 47,089 #12 Posted November 21, 2017 Here is a pic of the rubber strip I use to keep the cab from rubbing the hood paint. The round thingy is the magnet that holds it in place. 1 Share this post Link to post Share on other sites
t0urb0ss 2 #13 Posted November 22, 2017 I have a cab on my 416-8 with a two stage snowblower. They definitely are worth it when it's windy and you're clearing snow. Best compliment to the cab is a glass windshield and windshield wiper. I also mounted lights to the roof so night time cleaning is much easier. Share this post Link to post Share on other sites
608KEB 843 #14 Posted November 23, 2017 I bought a bicycle tube for between the cab and the hood. 1 Share this post Link to post Share on other sites
