Rayp 15 #1 Posted October 30, 2017 Can anyone please help with the following questions:- 1) Should the clip on the throttle cable bolt to the nut and bolt on the left of photo 1? 2) The spring in photo 1 doesn't appear to do anything - is it correctly located? 3) Where in photo 2 should the spring on the motion control lever be fitted? Share this post Link to post Share on other sites
rmaynard 16,287 #2 Posted October 30, 2017 12 minutes ago, Rayp said: Can anyone please help with the following questions:- 1) Should the clip on the throttle cable bolt to the nut and bolt on the left of photo 1? 2) The spring in photo 1 doesn't appear to do anything - is it correctly located? 3) Where in photo 2 should the spring on the motion control lever be fitted? 1. Yes, the clip is attached to that bolt and nut. 2. The spring (as far as I know) is to keep the arm from rattling. 3. Someone else will have to answer that one as I don't have that model tractor. 4 Share this post Link to post Share on other sites
rj35hunter 288 #3 Posted October 30, 2017 The spring in the first photo is for the PTO arm and lever just like mine in the photo 2 2 Share this post Link to post Share on other sites
Rayp 15 #4 Posted October 30, 2017 Thank you Hunter for the very clear photos - I can now make a little more progress with my rebuild Can I ask you another 'obvious' question namely is it possible to fit the belt guard without removing the fender. Thank you for your replies Bob. 1 Share this post Link to post Share on other sites
Rayp 15 #5 Posted October 30, 2017 Thank you for your replies Bob - I had assumed the spring in question had a critical role and was worried that it might not be the right one. 1 Share this post Link to post Share on other sites
Sarge 3,465 #6 Posted October 31, 2017 Got dimensions for that spring ? Mine has long moved to other pastures , it would be nice not to have it rattling or trying to burn the clutch disk off... Sarge Share this post Link to post Share on other sites
Rayp 15 #7 Posted October 31, 2017 4 hours ago, Sarge said: Hi Sarge, I,m sorry I don't have the de dimensions- I only wish I Had! I have tried to order this and two other springs without success and even asked the forum if anyone could give me dimensions of the springs I required but I got no response. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,429 #8 Posted October 31, 2017 Part number 1230 extension spring Wire .040" or 1mm diameter Distance between hooks 1.750" or 44mm Coil OD .350" or 9mm Coil length 1.024" or 26mm 24 coils @ 1.024" = .042667" wire diameter Garry Adding When you go to an online Toro dealer the 1230 comes up as a duplicate part See $book. They must have another part number for the same spring but it is not published yet. I will guess an experienced dealer dedicated to his service would know how to get that information. Probably in their latest price list. Same spring was used on some of the hydro tractors shift linkage http://www.partstree.com/parts/toro/parts/1230/ 3 Share this post Link to post Share on other sites
Rayp 15 #9 Posted November 1, 2017 Hi Garry, Thank you very much for the helpful information - I'm sure Sarge will be equally pleased. I will try the dealers again 'pre-armed'. Share this post Link to post Share on other sites
Sarge 3,465 #10 Posted November 1, 2017 Garry nailed it - and I think I already have that spring from some of my hydro units spare parts stash I keep around . Many of those parts are probably NLA since I always buy up several spares of things I think will wear out over time - springs are a big part of that box's contents . Bushings are another one - probably have 50 of them here and many for the pre-'73 models . Most are easy to duplicate/replicate/update/upgrade but some are very thin wall and tough to make on a sloppy old lathe I have....lol . Been asked by many a parts dealer why I want a quantity of 5 parts when it only takes just one... Sarge 1 Share this post Link to post Share on other sites
BOB ELLISON 2,981 #11 Posted November 1, 2017 15 hours ago, gwest_ca said: Part number 1230 extension spring Wire .040" or 1mm diameter Distance between hooks 1.750" or 44mm Coil OD .350" or 9mm Coil length 1.024" or 26mm 24 coils @ 1.024" = .042667" wire diameter Garry Adding When you go to an online Toro dealer the 1230 comes up as a duplicate part See $book. They must have another part number for the same spring but it is not published yet. I will guess an experienced dealer dedicated to his service would know how to get that information. Probably in their latest price list. Same spring was used on some of the hydro tractors shift linkage http://www.partstree.com/parts/toro/parts/1230/ I did some research on this spring and found some say the toro 83-2820 spring replaces #1230 spring. They are a little expensive for a replacement. 1 Share this post Link to post Share on other sites
Sarge 3,465 #12 Posted November 1, 2017 In some of the older Hardware stores there is a selection of springs in small drawers - can't recall who made them now but I've relied on those springs ever since I started building/repairing things . They are common wire sizes , diameter lengths , coil count and such and easy to find an exact match in many cases . There are some odd ones that used harder spring steel but most are honestly off-the-shelf common components . There was no reason to have a spring manufacturer make a proprietary part (except really odd stuff , like the HY unit for round hoods) . Most times I do exactly what Garry listed - wire diameter/coil OD/coil length/# of coils/distance to attachment type/style points . With that information - you can find nearly any spring . Beware using any from overseas - their wire hardness/ductility is not the same and many times will not last , break right away or corrode into a pile of dust . Sarge 1 Share this post Link to post Share on other sites
Rayp 15 #13 Posted November 2, 2017 Thanks again Bob and Garry and Sarge for all your help. Share this post Link to post Share on other sites
