Walt 339 #1 Posted October 29, 2017 I haven't ran my tractor since last spring due to a couple of my Grand Kids wanting to earn some money I let them use the walk behind to mow a few lawns. Yesterday I pulled both walk behind snow blowers out of the shed to prep them for upcoming winter. After I that I rolled my tractor out of the garage to start getting it ready for snow. I had to char battery it since it had set for 6 months or so. Once that was done and fuel was filling the fuel line it started fine. I let it run for a bit while getting lawn edger and shovel rounded up for today. When I went to shut tractor down I turned the key to off position and tractor stayed running turned it on and off couple of times and it continued to run. I lifted the seat and engaged the PTO and the tractor still stayed running. Do any of you have a direction for me to focus on when I dig into the cause of this over next few days while the rain keeps me from working with out a roof over my head. Tractor is a 1980 1100 Special with a BS engine. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,846 #2 Posted October 29, 2017 With the B&S powered models the ignition is self-powered and the ignition wire is simply grounded to the chassis or battery (-) to shut it OFF. Normally the ignition switch is a magneto type to accomplish this. The B&S tractors at the time used a different battery style of ignition switch and the I terminal that normally powers a battery style of ignition is used to power a relay. Key ON the relay contacts open and allow the B&S to run. Power OFF the relay grounds the ignition wire shutting the engine OFF. Your wiring should be similar to this Garry 2 Share this post Link to post Share on other sites
squonk 44,866 #3 Posted October 29, 2017 Sounds like the relay isn't relaying or the grounding wire became unhooked. Look fro a wire from under the f;ywheel hanging in mid-air. 2 Share this post Link to post Share on other sites
953 nut 63,031 #4 Posted October 29, 2017 Could be the relay is not all the way in the socket or the wire from the relay to the engine isn't hooked up. 1 Share this post Link to post Share on other sites
Walt 339 #5 Posted October 31, 2017 On 10/29/2017 at 11:23 AM, squonk said: Look fro a wire from under the f;ywheel hanging in mid-air. The lug on the end of that wire had broken off and sure enough it was just hanging there took about 5 minutes to replace the end and reattach it to the spade it was originally connected to. 1 1 Share this post Link to post Share on other sites
