W/H JUNKY 43 #1 Posted October 20, 2017 Hey guys. Got an issue iam looking for two items and iam hoping you guys can help. The frist and most important is a gasket 5999. The one that goes between the to halfs of the rear end of the D160. The other is the rear hubs for the D160. Any help well be much appreciated. Thanks in advance Share this post Link to post Share on other sites
"D"- Man 827 #2 Posted October 20, 2017 Does it look like this? Share this post Link to post Share on other sites
W/H JUNKY 43 #3 Posted October 20, 2017 I have not taking it out yet was trying to find a gasket before I opened it up. Share this post Link to post Share on other sites
pfrederi 19,131 #4 Posted October 20, 2017 (edited) Get a sheet of gasket material (thin 1/32") and make your own. ( Manila folders work also with some Permatex spray high tack gasket sealant.) What ever you do do NOT use RTV silicone. One small piece falling off can foul an acceleration valve port. Hubs check with A to Z in the vendors section. Did your break? Edited October 20, 2017 by pfrederi Share this post Link to post Share on other sites
pacer 3,177 #5 Posted October 21, 2017 The gaskets are "NLA "- no longer available So youll have to make your own - unless somebody has one left in their stock - they are pretty easy to make, there was recently a quite long post on this very topic. Do you need to replace your hubs, or need to get them off the axle? Share this post Link to post Share on other sites
W/H JUNKY 43 #6 Posted October 21, 2017 I just need to replace the ones that are on there. The guy I got the tractor from put hubs from a C series tractor and I would like to go bad to the D series hub and go back to the right size tire 1 Share this post Link to post Share on other sites
