chev0545 236 #1 Posted October 20, 2017 when i turn the steering all the way to the left i get this loud clicking.it will keep doing it as long as i keep turning it. thanks 1 Share this post Link to post Share on other sites
slammer302 2,156 #2 Posted October 20, 2017 Sounds like the steering gear and fan gear are not meshing properly or teeth are worn on one or both. 2 Share this post Link to post Share on other sites
R. L. Addison 299 #3 Posted October 20, 2017 Your bevel (pinion) gear is jumping over the tooth in the fan gear. These can be shimmed & the steering gear maybe moved down (if it has moved up over a period of time) or if it hasn't been serviced (greased) properly the bracket may be worn badly. Also the fan gear could have a chipped tooth (or worn). They can sometimes be beyond repair & need replacement. Only you can make that determination. 2 Share this post Link to post Share on other sites
midpack 1,009 #4 Posted October 20, 2017 the 417 I got last spring did the same thing. i used a large washer to shim it and now it's fine. funny... none of my C series machines have that problem 1 Share this post Link to post Share on other sites
chev0545 236 #5 Posted October 20, 2017 3 hours ago, midpack said: the 417 I got last spring did the same thing. i used a large washer to shim it and now it's fine. funny... none of my C series machines have that problem mine either Share this post Link to post Share on other sites
squonk 43,750 #6 Posted October 20, 2017 7 hours ago, chev0545 said: mine either I think the stouter hood stands on the older models have something to do with this phenomenon. 2 Share this post Link to post Share on other sites
ericj 1,579 #7 Posted October 20, 2017 I've seen the block broken and in one case of one tractor that I had, it had been brazed repaired, I believe I remember of a tractor or two C series skipping like that. eric j 2 Share this post Link to post Share on other sites
chev0545 236 #8 Posted November 11, 2017 took it apart two teeth broke off 1 1 Share this post Link to post Share on other sites
953 nut 59,848 #9 Posted November 11, 2017 Should be able to get a good one from A-Z Tractor. http://a-ztractor.com/ 1 Share this post Link to post Share on other sites
