ebinmaine 77,684 #1 Posted October 16, 2017 Given the splash-lube system.... how much can I be at an angle? Share this post Link to post Share on other sites
953 nut 64,540 #2 Posted October 16, 2017 According to Kohler it is 25* 3 Share this post Link to post Share on other sites
ebinmaine 77,684 #3 Posted October 16, 2017 11 minutes ago, 953 nut said: According to Kohler it is 25* ok cool ... . To be honest... I'M not comfortable at 25* anyways.... can't hold on !!! 3 Share this post Link to post Share on other sites
gregg'shorses 77 #4 Posted October 16, 2017 Also keep oil level to full line and try to minimize time spent on angle then run on level ground. 1 Share this post Link to post Share on other sites
Sparky-(Admin) 24,730 #5 Posted October 16, 2017 25 minutes ago, ebinmaine said: ok cool ... . To be honest... I'M not comfortable at 25* anyways.... can't hold on !!! If you add both front and rear wheel weights that'll make it a bit more stable with a lower center of gravity. 3 Share this post Link to post Share on other sites
skrusins 128 #6 Posted October 16, 2017 I have a lot of hills and keep the dipstick past the fill line because of the incline. Share this post Link to post Share on other sites
ebinmaine 77,684 #7 Posted October 16, 2017 22 minutes ago, Sparky said: If you add both front and rear wheel weights that'll make it a bit more stable with a lower center of gravity. I have 20 x 8 x 8 front, and 23 x 10.50 x 12 rears. All filled with Rimguard. Roughly 24 gallons for 260+ pounds extra weight. Stability is definitely good. My main concern is the engine, up/down hills because Everything I drive on is a Hill. From what you all are saying I should be fine. Share this post Link to post Share on other sites
shallowwatersailor 3,220 #8 Posted October 17, 2017 A 15% slope is equivalent to 8.53 degrees. Another way to look at is a rise of 30 inches in 10 feet. Always mow downhill and never coast down. Share this post Link to post Share on other sites
ebinmaine 77,684 #9 Posted October 17, 2017 10 hours ago, shallowwatersailor said: A 15% slope is equivalent to 8.53 degrees. Another way to look at is a rise of 30 inches in 10 feet. Always mow downhill and never coast down. Seems like I should be fine. One of my most common hills to be on is going from the front of the house to the back. Ranch with a daylight basement. Drops seven or eight feet vertically in 24 horizontal feet. Never hang around there. I never mow with this machine. I do tow some pretty heavy weights up and down those Hills. Always always always in gear. I'm not adventurous enough to Coast even unloaded. Share this post Link to post Share on other sites
