jellyghost 378 #1 Posted October 16, 2017 I am trying to find all of the zerk fittings on my C-101, and two spots have me puzzled. The center spindle on the mower deck does not have a zerk. I looked at some images online, and I couldn't find a wheel horse mower deck with a clear zerk on the center spindle. Is it missine a zerk or is there another way to grease this part? A while ago, someone suggested greasing the steering column and shaft joints. I have been looking at it, and I can't find any zerks. How do I grease this? Is it necessary? Thanks in advance! Clark Share this post Link to post Share on other sites
Lee1977 7,052 #2 Posted October 16, 2017 The center spindle zerk may be worn off. The tractor deck lift will hit it and wear it off. I remove my center zerk sand replace it with a fine tread set screw. The only time you can grease it is when the deck is removed. 3 Share this post Link to post Share on other sites
WildHorses 393 #3 Posted October 16, 2017 (edited) There will (or should be) be a grease zerk on top of all three spindles. The middle spindle has a tendency to rub on the lift rod on a lot of decks, it may have worn off the zerk. There is also a zerk on the base of the shaft that goes to the steering wheel around the geared block. It's sometimes caked in grease and difficult to find but it's there. You can find it referenced on page 22-23 of the owners manuals. Edited October 16, 2017 by WildHorses 1 1 Share this post Link to post Share on other sites
953 nut 58,200 #4 Posted October 16, 2017 9 hours ago, jellyghost said: greasing the steering column and shaft joints. This one will also require the deck being removed. It is on the bottom of the fan gear block where the two pieces mate up. 1 Share this post Link to post Share on other sites
tunahead72 2,519 #5 Posted October 16, 2017 If your center spindle grease fitting is worn off, you'll find some other ideas here: Share this post Link to post Share on other sites
Tankman 3,520 #6 Posted October 17, 2017 Keep an easy-out and spare zerk fittings in your tool box. Right angle zerk fittings are handy too. I've replaced quite a few grease fittings but more often front axle pin center. Use a block of wood if jacking up the front of your Horse! Share this post Link to post Share on other sites
JimD 3,345 #7 Posted October 17, 2017 My B60 and B80 have no spindle zerks on the deck. They are sealed bearings that need to be replaced when worn out. Is it possible that someone may have changed that spindle somewhere along the line? Share this post Link to post Share on other sites
redone 45 #8 Posted October 17, 2017 Hi All. I am searching for a metal plate that attaches to the starter on a 8 up Kohler. Its used to mount the coil, and solenoid Any ideas were to find one. Thank you Bill Share this post Link to post Share on other sites
953 nut 58,200 #9 Posted October 18, 2017 25 minutes ago, redone said: Hi All. I am searching for a metal plate that attaches to the starter on a 8 up Kohler. Its used to mount the coil, and solenoid Any ideas were to find one. Thank you Bill Best bet would be to place a wanted ad in classifieds, just click below. http://www.wheelhorseforum.com/classifieds/wanted/ Share this post Link to post Share on other sites
