carlosking450 158 #1 Posted October 12, 2017 Hello I would like to know which battery should I bring my WHEEL HORSE 702 Share this post Link to post Share on other sites
ACman 7,664 #2 Posted October 12, 2017 (edited) On this side of the pond we use mostly lawn and garden batteries (group U1)but I believe the battery tray holds a group #22NF battery . Here’s one source of batteries for Europe . https://www.yuasa.co.uk/batteries/leisure-marine-garden-view-all.html Edited October 12, 2017 by ACman 2 Share this post Link to post Share on other sites
rmaynard 16,404 #3 Posted October 12, 2017 I use a U1 battery in all of my Wheel Horses U1R has the negative terminal on the right as shown below. U1L is just the opposite. 6 Share this post Link to post Share on other sites
pfrederi 18,771 #4 Posted October 13, 2017 (edited) The U1 battery will be loose in the battery box..(if it is original) and will need to be shimmed., The 22NF will fit snugly. Edited October 13, 2017 by pfrederi 2 Share this post Link to post Share on other sites
carlosking450 158 #5 Posted October 17, 2017 sorry for not answering before, what power or amps should be? Share this post Link to post Share on other sites
rmaynard 16,404 #6 Posted October 17, 2017 The batteries that I use are usually 300 CCA (cold cranking amps). You don't need that much for a 702, but having more than enough power is better than not having enough. Share this post Link to post Share on other sites
carlosking450 158 #7 Posted October 17, 2017 Thanks¡ Share this post Link to post Share on other sites
squonk 44,036 #8 Posted October 18, 2017 Remember, The more power a battery has, the tighter the plates are packed and in most cases can shorten a battery's life. But even a 300A Battery at half the cranking amps will start a 702 as long as the voltage is 12.5 or higher. Share this post Link to post Share on other sites
