a.dumont 10 #1 Posted October 9, 2017 1973 Kohler K482S on a 18 Auto. Measured 20 volts a/c from the engine, so I know the stator is good. 0 volts d/c coming out of regulator/rectifier. Can I just use a universal regulator/rectifier? Has anyone had better luck with one brand/model over another? 1 Share this post Link to post Share on other sites
Achto 30,819 #2 Posted October 9, 2017 Give this site a try, they have reasonable prices on after regulators. http://www.psep.biz/store/kohler_voltage_regulator.htm 1 Share this post Link to post Share on other sites
Rob R 980 #3 Posted October 9, 2017 Double and triple chk you connector and all the grounds including the mounting bolts and back plate of the rectifier..... especially if anything in that area was re-painted or touched-up..... 3 Share this post Link to post Share on other sites
WHX?? 54,485 #4 Posted October 9, 2017 (edited) As above Dumont. ...sounds like you scored a real gem! Good luck and keep us posted might be better to do a single thread on this tractor for us to keep track and better help you out! In case you haven't been warned we do like our Edited October 9, 2017 by WHX12 Speeling 2 Share this post Link to post Share on other sites
a.dumont 10 #5 Posted October 23, 2017 Will do. As long as it continues to show promise, a full rebuild will be in its future. I'll single thread that and pictures will come shortly! Share this post Link to post Share on other sites
953 nut 63,916 #6 Posted October 23, 2017 On 10/8/2017 at 8:26 PM, a.dumont said: Measured 20 volts a/c from the engine, Should be in the 36 volt range at half throttle or above. 20 volts AC rectified to DC will produce about 9 volts. Share this post Link to post Share on other sites
BMW1 44 #7 Posted October 23, 2017 I used this one and it seems to work. This one has the 3 prong offset connector instead of the 3 prongs that are inline. https://www.dbelectrical.com/products/rectifier-regulator-john-deere-kohler-engines-15amp.html Share this post Link to post Share on other sites
