mikeeyre74 289 #1 Posted September 30, 2017 I think I'd rather stick my face in a bear trap than have to take Onan twin engine sheetmetal off ever again. Gah. Maybe I'm just not doing it right, but I'll be damned if that's not a really complicated hard to remove mess. Situation: Hour meter doesn't work I understand the hour meter listed to the oil pressure sensor to ground it and start the meter running. I noticed my meter isn't working, so I turned the key on and jumped the ground to battery with a test lead and she fires right up and clicks, so I know it's just not grounded. This led me to trying to find the oil pressure switch and then wanting to harm myself by hassling with that damned sheetmetal that was in the way. I did find a dead mouse behind the cover, so it was, all in all, a good thing. Anyway, I can't figure out how to test the system now before I put it back together? I can't run the engine to get the pressure to build because I have all the wires and fuel stuff disconnected and moved out of the way to get the shroud off. Is there a way to test the oil pressure sensor without it running? Is there a way to test the whole system then, without it running? I'd have thought jumping the two spade connectors on the pressure switch would have made the hour meter start running, but it doesn't... what gives? Mike Share this post Link to post Share on other sites
608KEB 797 #2 Posted September 30, 2017 I had the same problem 1 1/2 years ago on my 520H. I had to put it back together In order to see if the hour meter worked. Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,561 #3 Posted September 30, 2017 The blue wire at the oil pressure switch grounds the oil light when the pressure is low or 0. The black wire at the oil pressure switch grounds the hour meter when there is oil pressure. Two totally separate circuits controlled by two circuits in a single pressure switch. Garry 1 1 Share this post Link to post Share on other sites
squonk 44,036 #4 Posted September 30, 2017 You could cut the ground wire and just run a new one to the chassis or battery ground. It won't be correct and will add hours if you leave the key on but at least it will work. I have a different problem with mine. The meter works when it wants to and it's not losing power or ground. Bad meter. Share this post Link to post Share on other sites
cleat 7,392 #5 Posted September 30, 2017 All of my 520's came with non functional hour meters so I do not know for sure how many hours are on any of them. 3 of them now have electronic digital hour meters and one has a new Hobbs replacement. All of them are wired with their own ground so will work even if engine is no running but I don't know why I would leave the key on without engine running. Share this post Link to post Share on other sites
mikeeyre74 289 #6 Posted September 30, 2017 5 hours ago, gwest_ca said: The blue wire at the oil pressure switch grounds the oil light when the pressure is low or 0. The black wire at the oil pressure switch grounds the hour meter when there is oil pressure. Two totally separate circuits controlled by two circuits in a single pressure switch. Garry Any idea of an easy way to test this set of circuits without having the engine running? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,561 #7 Posted September 30, 2017 You would need to remove the switch and come up with source of applying a controlled pressure to the switch. The easiest may be a hand tire pump connected to a low pressure gauge and the switch. Garry 1 Share this post Link to post Share on other sites
mikeeyre74 289 #8 Posted September 30, 2017 If I'm reading this wiring diagram correctly, if I hook a test light from the positive terminal of my battery and touch one of the switches probes with the engine off, one of them should light the lamp and the other one should not. Then, if the engine is spinning, that same terminal should turn the light off, but should be lit up on the other terminal, is that correct? 1 Share this post Link to post Share on other sites
953 nut 60,724 #9 Posted September 30, 2017 Sounds right to me. Share this post Link to post Share on other sites
mikeeyre74 289 #10 Posted September 30, 2017 And failure! I went and pulled the switch out and tested it in hand and under pressure. NO function at all, no matter what I do. It's internally mucked up. I can't seem to find a good replacement part number.. this ones listed as NLA. Onanparts.com is "gone fishing" until november.. Anyone got a lead on a replacement? 1 Share this post Link to post Share on other sites
cleat 7,392 #11 Posted September 30, 2017 Lots of Onan low oil pressure switches on ebay. No Wheel Horse specific ones right now but there usually is. 1 Share this post Link to post Share on other sites
mikeeyre74 289 #12 Posted October 1, 2017 So then... if the original part isn't available anymore, but you can still get the one terminal ones, if I installed that (connection made at 5psi style), I could line that back up with my hourmeter and make that circuit run again... but my idiot light for the low pressure would be DOA. That's the magic of the two circuit switch, correct? OR: Does it make more sense to wire the hour meter up with its own ground off of the oil pressure circuit (have to go with Key ON action and try and remember not to just leave it on..) and use a different oil pressure switch which would be mormally CLOSED at 0psi and open at pressure above that and have that wired in with the idiot light? That would be safer I guess? Share this post Link to post Share on other sites
cleat 7,392 #13 Posted October 1, 2017 The older 520's came with a single contact pressure switch. That controlled the flashing oil light only. The hour meter ran when key on irregardless of engine running or not. Wheel horse 520H wire diagram.pdf Cleat Share this post Link to post Share on other sites
mikeeyre74 289 #14 Posted October 1, 2017 What years would that be on so I can get a pressure switch like that, then? Or, better yet, if you have the part number in your head that's fine too... Share this post Link to post Share on other sites
mikeeyre74 289 #15 Posted October 1, 2017 After a little research, it looks like this PS122 switch from Wells would work, yes? It has three terminals on it, but looks like it's a NC/NO action like the two position original equipment, but the third terminal works in mirror to the 1st teminal. If I ignore that extra terminal, it will function as I need it to. And at $6, it's not a bad deal! http://www.wellsve.com/showall_ds_oil.php Can anyone confirm? Its NC at 0psi, and opens at 2.5 to 12 psi on the other terminal, according to their site that linked above. Mike Share this post Link to post Share on other sites
mikeeyre74 289 #16 Posted October 5, 2017 I answered my own question. For anyone following this thread, read this: Share this post Link to post Share on other sites
