mikeeyre74 289 #1 Posted September 25, 2017 Do I have to pull the engine to get the regulator out of this Onan in my 520?I've got the two nearest bolts out of the sheetmetal nearest to it, but it won't wiggle out of there. It seems me I need to pull the engine up and out to get all the metal shroud out of the way to get the regulator out from under that metalwork. Is there a better way? Share this post Link to post Share on other sites
ericj 1,579 #2 Posted September 25, 2017 pull the hold down bolt out and slide the regulator, forgive me I forget if it is bask or forward, possible forward the take a screw driver and gently pry up on the sheet metal and it should pop out. may not be the correct way but it worked for me. good luck eric j Share this post Link to post Share on other sites
mikeeyre74 289 #3 Posted September 25, 2017 You're right. It wasn't UNDER the sheetmetal as I thought it was... it was just stuck. It came right out with a little leverage. And, it's broke, so there's that.. 1 Share this post Link to post Share on other sites
