seven 202 #1 Posted September 23, 2017 Have a 12 horse k 301 i was wondering if anyone has ever converted over or is not possible? Seems like I'm always having trouble with my points getting corroded. Share this post Link to post Share on other sites
Ed Kennell 44,666 #2 Posted September 23, 2017 I can't answer your conversion question, But have you replaced the condenser and put in the correct plug? Personally, I prefer the points ignition. 3 1 Share this post Link to post Share on other sites
squonk 45,372 #3 Posted September 23, 2017 Gasket and grommet in place on the points cover to keep the gremlins out? 3 Share this post Link to post Share on other sites
Fordiesel69 271 #4 Posted September 25, 2017 You would need a Kohler Magnum M12 as a donor engine to get the parts you need. It would require the side bearing plate with stator, flywheel, starter, magneto, and tins. From there you would rewire the IGN switch to GROUND the coil wire to kill engine instead. You typically have to get a new ign switch. You may consider getting a used set of points and condensor from someone on here. The new aftermarket ones are junk / un-usable. Good tip on the gasket and grommet. They are very important!!!! 1 Share this post Link to post Share on other sites
