96WS6TA 37 #1 Posted September 22, 2017 I have a 416h with the 16 onan just pulled her for off for a carbon and gasket job. finally got her back together and started and purred like a kitten 20 sec later she dies, let her sit for a min or 2 and starts up runs and dies again.. new plugs wires fuel lines filter pump. now my buddies 20 onan was doin the exact same thing and we replaced the crank trigger and that was the problem. now is there any way to test the crank trigger? hate to spend all the $$ on a new one??? Share this post Link to post Share on other sites
cleat 9,339 #2 Posted September 23, 2017 If it ran good before then I would check everything you touched and make sure you did not mess anything up. For the trigger to fail at the exact time you de-carboned it seems like a real coincidence. 2 Share this post Link to post Share on other sites
ericj 1,580 #3 Posted September 23, 2017 6 hours ago, 96WS6TA said: I have a 416h with the 16 onan just pulled her for off for a carbon and gasket job. finally got her back together and started and purred like a kitten 20 sec later she dies, let her sit for a min or 2 and starts up runs and dies again.. new plugs wires fuel lines filter pump. now my buddies 20 onan was doin the exact same thing and we replaced the crank trigger and that was the problem. now is there any way to test the crank trigger? hate to spend all the $$ on a new one??? check the onan service manual, basically turn switch on and put test leads on negative side of the battery and the negative side of the coil spin the motor over by hand, you may want to pull the plug wires off while doing this to prevent accidental starting, your voltage should go from battery 12 volts down to 1 1/2 volts and then back to 12 volts . you must do this when the motor quits and won't restart. I say you have either a fuel problem or possible a voltage issue getting to power the coil. you can run a jumper from the positive coil terminal to the positive battery terminal and see if ti stays running. good luck eric j Share this post Link to post Share on other sites
96WS6TA 37 #4 Posted October 2, 2017 fixed! it was in fact the crank trigger! 2nd one ive known to go bad Share this post Link to post Share on other sites
boomers_influence 106 #5 Posted October 2, 2017 96W there is an ignition control, ( module ) and an ignition rotor.( on the crank ) which did you replace? thank you. boomer ( the used onan engine parts guy, also NOS and new ) Share this post Link to post Share on other sites
