USHorse 41 #1 Posted September 21, 2017 Anybody know the max torque output of these engines. Want to compare to 16 hp Carroll Stream and 22 hp predator.....tx Share this post Link to post Share on other sites
skippy1969 135 #2 Posted September 22, 2017 I know the K341(16hp) peak torque is 28.25ft lbs. @2600rpm with max. brake hp 16@3500rpm torque is 23.5ft. lbs. And according to the Harborfreight site the Predator 22hp has 45 NM or 33.19 ft. lbs. at 2500 rpm. 3 Share this post Link to post Share on other sites
USHorse 41 #3 Posted September 23, 2017 Thank u. I now see why people love those kohlers Share this post Link to post Share on other sites
Sarge 3,471 #4 Posted September 23, 2017 Yeah - it takes a much larger engine to produce enough torque to match the larger K series cast iron line - plus , their rotational weight is what helps them stay at their pulling rpm range . It's tough to knock one off it's power band without destroying belts/clutches downstream of that torque monster . If you like the specs of the K-341 - check out the even heavier built K-482/532/662 , 48/53/66 cu/in twin opposed design . Those are the real torque monsters. The larger twin K series are known to destroy belts and clutches easily if the implement is overloaded . One thing to note - older engines like these were pretty underrated in comparison to the newer ones available with the exception of a diesel . Even a 22hp Predator , 21-23hp Briggs Vanguard will not pull like a Kohler - large bore/stroke single cylinders engines are a real treat to operate . Find a running condition K-361 18hp overhead valve - they are a work of art and will bury any modern v-twin in performance . I have seen only one of them , and that guy isn't going to turn loose of it any time soon . The overhead valve design made a huge difference in torque and response to an already powerful engine - once the vent issue is addressed they are amazing . Sarge Share this post Link to post Share on other sites
