fordsonmajortom 1 #1 Posted February 13, 2009 Hi The belt tensioner pulley on my lawnranger is on its last legs. I have looked on the Toro parts site for the part number but there's no drawing to tell me which pulley is which. Can you still get this pulley as it is smaller than the ones on my other horse's or do i have to put a larger pulley on it. Thanks Michael :thumbs: Share this post Link to post Share on other sites
sorekiwi 761 #2 Posted February 13, 2009 The parts look-up at RCPW lists the tensioner pulley as #1623 (superceeded to 92-7102) for $31 or so. The balls in the bearing must be gold!! Share this post Link to post Share on other sites
kpinnc 16,230 #3 Posted February 13, 2009 I think I'd check tractor supply or a similar place too. They have some for about $8. It won't be OEM by any means, but it's close enough for under the belt guard... Kevin Share this post Link to post Share on other sites
Stigian 1,235 #4 Posted February 15, 2009 Hi Micheal, if you could post a photo of your rangers belt tensioner pulley I will have a look and see what i have in my parts stock. You never know, I might have just the part sitting about :thumbs: Share this post Link to post Share on other sites
Teddy da Bear 11 #5 Posted February 16, 2009 Also.....when Toro.com does not have drawings.... Go to Partstree.com and often they will. Share this post Link to post Share on other sites
fordsonmajortom 1 #6 Posted February 16, 2009 Hi Micheal, if you could post a photo of your rangers belt tensioner pulley I will have a look and see what i have in my parts stock. You never know, I might have just the part sitting about Hi Ian , The diameter of the pulley is about 3 1/16 diameter with a hole to take a 3/8 bolt. It would be great if you had got one. Michael. Share this post Link to post Share on other sites
