520hC-120 136 #1 Posted September 16, 2017 What type of oil does my 1976 Wheel Horse C-120's automatic tranny take? any help would be great, Thank You Share this post Link to post Share on other sites
953 nut 60,348 #2 Posted September 16, 2017 It probably has 10W30 motor oil in it. If the oil is an amber color it is 10W30, if it is red it is Dextron ATF. 2 1 Share this post Link to post Share on other sites
JimmyJam 542 #3 Posted September 16, 2017 Depends what was used prior. If it is reddish in color than automatic transmission fluid was used. If it is brownish in color than gear oil was used. Share this post Link to post Share on other sites
520hC-120 136 #4 Posted September 16, 2017 ok, it does smell like classic transmission oil but I think the guy before me put in the wrong stuff, My 520H takes 10w30 so i guessed it would be the same Share this post Link to post Share on other sites
953 nut 60,348 #5 Posted September 16, 2017 24 minutes ago, JimmyJam said: If it is brownish in color than gear oil was used If GEAR OIL was used in a hydro it would be trashed! 24 minutes ago, 520hC-120 said: ok, it does smell like classic transmission oil but I think the guy before me put in the wrong stuff, My 520H takes 10w30 so i guessed it would be the same If in doubt you could pick up a couple of gallons of 10W30 and a couple of filters. Change out the present fluid and filter, run it around the yard until it is warmed up running the lift up and down a few times then drain and change it and replace the filter. That will flush out the old stuff. 1 Share this post Link to post Share on other sites
520hC-120 136 #6 Posted September 17, 2017 So my C-120 most likely takes 10w30, right? 1 1 Share this post Link to post Share on other sites
520hC-120 136 #7 Posted September 17, 2017 Thank You Guys Share this post Link to post Share on other sites
JimmyJam 542 #8 Posted September 17, 2017 3 hours ago, 953 nut said: If GEAR OIL was used in a hydro it would be trashed! Sorry 953! I meant motor oil. My 1968 Electro 12 Owner's Manual states for the Sundstand transmission to use automatic transmission fluid. I have heard guys use motor oil. You are right a good flushing is needed! 1 Share this post Link to post Share on other sites
