Ronwheel82 0 #1 Posted September 16, 2017 (edited) So I just got a new ignition switch for my 1992 416 h and when I installed it my test switch crumbled into pieces now I can't get it to fire up Edited September 16, 2017 by Ronwheel82 Left out model Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,562 #2 Posted September 16, 2017 The test switch is powered by 12 volts from the battery so make sure the red wire is not shorted to ground. You likely blew a fuse if it did short. The light panel does not have any influence on the tractor wiring. You can unplug the circuit board if you want. Garry Adding - make sure your new ignition switch has one terminal identified by the letter I (eye). There are identical switches except for a letter M on them for the ignition and they are not correct for this model. 1 Share this post Link to post Share on other sites
rmaynard 16,404 #3 Posted September 16, 2017 When Garry said "The light panel does not have any influence on the tractor wiring."I would add that that is true unless the panel or the 9-pin connector is shorted, in which case it could cause a problem with other tractor wiring. 1 Share this post Link to post Share on other sites
Ronwheel82 0 #4 Posted September 17, 2017 I checked to make sure red wire was not grounded and my 25A fuse stopped blowing, but now when I took up the battery I get nothing when I turn the key. Any thoughts? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,562 #5 Posted September 17, 2017 Pto OFF? Try pulling it farther into the OFF position while cranking. Transmission in neutral? Those 2 switches control the power from the S terminal on the ignition switch. 30 amps fuse OK? It powers the start relay and the above two switches control it. Garry Share this post Link to post Share on other sites
Ronwheel82 0 #6 Posted September 17, 2017 I will defiantly check those, thank you very much for the advice! Share this post Link to post Share on other sites
