williambogner 0 #1 Posted February 12, 2009 Hey guys. Ive never delt with a Kohler before. I got a k301 and just wondering if im going to run into any trouble putting new points in. Condensor is just a bolt-on thing. Is it easy to put in and adjusting?? All the help would be good. I got a good idea of what to do but never have put new ones in...thanks Share this post Link to post Share on other sites
nylyon-(Admin) 8,504 #2 Posted February 12, 2009 It's easy. Remove the 2 screws on the breaker cover, rotate the engine until the points are fully opened, remove the points. Install the new ones and set the gap to .020. Share this post Link to post Share on other sites
WHC-125 4 #3 Posted February 12, 2009 Make sure they are gapped right though or it will run like crap And will you should ad some of the pics that you sent to me on here of your restoration of the 12 Auto. :thumbs: Share this post Link to post Share on other sites
williambogner 0 #4 Posted February 12, 2009 haha what should i use to gap it?? feeler gauge or something? Share this post Link to post Share on other sites
WHC-125 4 #5 Posted February 12, 2009 Feeler Gauge would work the best in my opinion. And Advance Auto has them for $5.00 Share this post Link to post Share on other sites
williambogner 0 #6 Posted February 12, 2009 Ok once again posting AGAIN!! I got some ignition points and after i took the cover off i spun the flywheel to open the ignition points all the way up. well the ignition bar wont go in or out.? even if i take the ignition itself away the bar wont come out or go in. ANY help would be appreciated. Thanks William Share this post Link to post Share on other sites
WHC-125 4 #7 Posted February 13, 2009 The push rod wont come out? :thumbs: Share this post Link to post Share on other sites
sawhorse 0 #8 Posted February 13, 2009 I think those electronic "thingys" that replace both the points and condenser are still available. Might have been Northern tool where I saw them for sale. I'm not of any help with the old points and condenser, I've been down that road. :thumbs: Share this post Link to post Share on other sites
Rollerman 290 #9 Posted February 13, 2009 The pushrod does not move much. Double check also that the push rod is free in the hole going hrough the block. (Topic moved & merged to the Kohler engine section) Share this post Link to post Share on other sites
williambogner 0 #10 Posted February 13, 2009 ahh tickster. Thanks i got it...it wasnt going through properly but all set now. thanks a lot Share this post Link to post Share on other sites
