Lcarter114 4 #1 Posted September 10, 2017 I have a model 417A with a Kohler series I I engine, spec number 24363. The oil pressure sensor is leaking. I can not find a part number for it anywhere. All the diagrams I can find show the switch but give no part numbers. Does anyone know what the part number is? Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,532 #2 Posted September 10, 2017 Welcome to the forum. Engine supplied by Kohler so they likely supplied the oil pressure switch also. Garry 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,532 #3 Posted September 10, 2017 5209903 switch on page 14 Replaced by 5209905 replaced by 2409903 replaced by 2409903-S http://www.partstree.com/parts/kohler-engines/parts/24-099-03-s/ Garry 1 Share this post Link to post Share on other sites
Lcarter114 4 #4 Posted September 11, 2017 Thanks for the info, I spent 4 hours this morning trying to find the part number Share this post Link to post Share on other sites
Lcarter114 4 #5 Posted September 16, 2017 Okay, got the switch and went to put or on and the adapter broke. I ran all over town looking for the adapter but can not find it. I didn't see it in the parts list umess it is something eles. Any ideas on the part number or type of adapter I need? Thanks Share this post Link to post Share on other sites
pfrederi 21,297 #6 Posted September 16, 2017 (edited) The block is drilled an tapped for 1/8 27TPI pipe threads...which is what the pressure switch should have..no adapter needed unless you have a clearance issues with the ear on eh bearing end plate. In which case you can use brass 1/8" pipe fittings to solve it probably a short nipple and a connector. Edited September 16, 2017 by pfrederi Share this post Link to post Share on other sites
Lcarter114 4 #7 Posted September 16, 2017 The pressure switch threads are 1/4" I believe. I have attached pictures of the switch and adapter. Share this post Link to post Share on other sites
pfrederi 21,297 #8 Posted September 16, 2017 Still pipe thread get a reducer like this and 1/8" nipple and you are set. Any hardware store should have it. You might even find a 1/4 female 1/8 male making it a one piece solution. Share this post Link to post Share on other sites
woodchuckfarmer 333 #9 Posted September 17, 2017 My KT 17 did the same thing. But I couldn't get the other part out of the block, so taped it 8-32 and put a set screw in it to stop the oil from poring out. Ill have to pull the engine and drill it out and tap it 1/8 inch pipe thread later this fall. Share this post Link to post Share on other sites
Sarge 3,473 #10 Posted September 17, 2017 Good auto parts stores should have a large cabinet with a selection of brass fittings for brakes , oil and fuel . If it's an Edelman assortment - it should have the short 1/8"NPTx1/4"NPTF reducer as that one is specific . Otherwise , check with McMaster - I believe they keep them in stock . Some of the home centers also have extensive brass fittings , but good luck trying to hunt through them . Sarge 1 Share this post Link to post Share on other sites
Lcarter114 4 #11 Posted September 18, 2017 I ended up ordering the fitting from McMaster. Thanks for the info. Hopefully this is the lasthma problem I run into with this project. Thanks again. Share this post Link to post Share on other sites
