AlwaysLookin80 1,308 #1 Posted September 5, 2017 Did all rj 35s come with reverse gear or not. And are they hard to get into reverse? Thank you Share this post Link to post Share on other sites
953 nut 62,782 #2 Posted September 5, 2017 The engine pulley on the RJ-35 has a brass ring embedded into it that contacts the variable speed pulley causing it to rotate backward, that is how you go in reverse. There is a member here who has reproduced them from time to time, if you place a "Wanted" ad in the classified section he may have one left. Share this post Link to post Share on other sites
neil 2,415 #3 Posted September 5, 2017 Joe Papke , does a replica reverse disc,. do all RJ35s make an awful noise when they are put in reverse ?& are all Rjs hard to hand push around ? 1 Share this post Link to post Share on other sites
buckrancher 2,695 #4 Posted September 5, 2017 all but mine Neil remove the long drive belt to free roll the tractor around Brian 1 Share this post Link to post Share on other sites
Lane Ranger 11,655 #5 Posted June 16 (edited) On 9/5/2017 at 6:04 AM, 953 nut said: The engine pulley on the RJ-35 has a brass ring embedded into it that contacts the variable speed pulley causing it to rotate backward, that is how you go in reverse. There is a member here who has reproduced them from time to time, if you place a "Wanted" ad in the classified section he may have one left. Richard (953). Described it Joe Papke was remaking these a couple years ago. This is an original. Edited June 16 by Lane Ranger Share this post Link to post Share on other sites
