TimH 105 #1 Posted August 31, 2017 What are being used to replace the floor board Foot pads ? Share this post Link to post Share on other sites
Texas Todd 1,026 #2 Posted August 31, 2017 I've used aluminum diamond plate as well as black abrasive and self adhesive stair tread material. Kind of like skateboard tape. Got both at Home Improvement store. 2 Share this post Link to post Share on other sites
AMC RULES 37,259 #3 Posted August 31, 2017 http://www.classickitchensandmore.com/wheel-horse-tractors-parts-c-42/ 5 Share this post Link to post Share on other sites
ohiofarmer 3,470 #4 Posted August 31, 2017 I just mask off the footboard area and add sand to black Rustoleum. You could also add black beauty blasting media for a more coarse grit. Then follow up with another coat of black paint. I like this system because it is so inexpensive and the rust does not start underneath the glued on floorboards. I used it on a motorcycle lift that gets walked on almost daily and it holds up fine. 4 1 Share this post Link to post Share on other sites
Texas Todd 1,026 #5 Posted August 31, 2017 I guess spray on bed liner would also work well. Good point about rust developing beneath the aluminum. Share this post Link to post Share on other sites
DOC in Kentucky 178 #6 Posted September 3, 2017 The items from Eldon at Classic Kitchens cants be beat, IMO! Easy to apply, fit great, wear real well, non-slip and look very original!!! 2 1 Share this post Link to post Share on other sites
doc724 927 #7 Posted September 3, 2017 Go to Kofflersales.com. They sell non skid adhesive backed tape from 3M. you can get a 6 inch x 24 inch piece of tape (enough for both floor boards) for $3.29 and shipping is maybe $4. No yellow stripe either. Buy the 60 grit stuff and it is an exact replacement (although it is 1/2 wider than original WH part) 1 Share this post Link to post Share on other sites
1995 520H+96+97 939 #8 Posted September 4, 2017 (edited) I used conveyor belting. Makes cleaning snow, salt, dirt, pebbles, and dirt a lot easier. I cut the outside edge 3/8 oversize so the water won't touch the running board. Edited September 4, 2017 by 1995 520H+96+97 2 Share this post Link to post Share on other sites
Forest Road 595 #9 Posted October 22, 2017 I like the spray on bed liner. Fast, easy, and affordable. Share this post Link to post Share on other sites
ebinmaine 80,418 #10 Posted October 27, 2017 On 9/3/2017 at 7:49 PM, doc724 said: Go to Kofflersales.com. Thanks for the lead on that! I just ordered some. 2 Share this post Link to post Share on other sites
Tankman 3,528 #11 Posted November 5, 2017 (edited) Coarse skateboard grip tape. Works great and wears well. One piece does both footrests. Edited November 5, 2017 by Tankman 4 1 Share this post Link to post Share on other sites
Lee1977 7,750 #12 Posted November 9, 2017 I use what I have, and I had some 2" wide 3M safety tape left over from replacing it on an aluminum running board on an Old Ford van I had. I used two strips that left a Red painted strip down the center. Share this post Link to post Share on other sites
