carlosking450 161 #1 Posted August 29, 2017 Hello again friends, I want to mount my 702 rear wheels with cleats, the measure I am going to buy is the correct 6.00-12 but I notice that the new wheel has a lot of taco and I am afraid that I rub with the rear cubers. Of the 6.00-12 wheel includes the height of the studs true bone I do not have to have any problems Share this post Link to post Share on other sites
C-101plowerpower 1,606 #2 Posted August 29, 2017 i dont know what translater you are using, but it really doesnt make any sence with technical stuff and proper sentences, sorry Share this post Link to post Share on other sites
carlosking450 161 #3 Posted August 29, 2017 I have changed translator. My doubt is for that I am going to buy a few back tires for my 702, the original measure is 6.00-12 that it is the same that I am going to put, but it seems to me that plug has very much and not if I was rubbing shoulders with the back mudguard I refer that the rut of the tire is very high, but if it is the same measure I do not have to have ningun problem Share this post Link to post Share on other sites
ACman 7,722 #4 Posted August 29, 2017 Could you post a picture of the tire in question ? Share this post Link to post Share on other sites
cafoose 3,736 #5 Posted August 29, 2017 Tal vez si lo publicas en español, podemos usar nuestro traductor Maybe if you post it in Spanish we can use our translator Share this post Link to post Share on other sites
ol550 863 #6 Posted August 29, 2017 6-12 is not the same size tire as 6.00-12. The 6-12 will be smaller. Share this post Link to post Share on other sites
carlosking450 161 #7 Posted August 29, 2017 I wrote it wrong, but it's 6.00-12 Share this post Link to post Share on other sites
wheelhorseman 3,256 #8 Posted August 29, 2017 I just put new 6-12 tires on my 702. Here is a picture and a link for reference so you can get the correct ones over there. https://m.summitracing.com/parts/crr-5233c3 6 Share this post Link to post Share on other sites
RedRanger 1,470 #9 Posted August 30, 2017 18 hours ago, wheelhorseman said: I just put new 6-12 tires on my 702. Here is a picture and a link for reference so you can get the correct ones over there. https://m.summitracing.com/parts/crr-5233c3 Now THAT's an attachment I've not seen before! Also a great deal on the 6-12 tires. I paid around $85 each for mine. 1 Share this post Link to post Share on other sites
carlosking450 161 #10 Posted August 30, 2017 Hola otra vez ahora os escribo en español,lo primero gracias por vuestro interes.He visto aqui en España las ruedas de las fotos son completamente nuevas y la medida es la original 6.00-12 para mi wheel horse 702.Pero a simple vista tengo la senasacion de que el taco o dibujo de la rueda es muy alto y tengo miedo de que la rueda choque contra el cubre rueda. Share this post Link to post Share on other sites
wheelhorseman 3,256 #11 Posted August 30, 2017 1 hour ago, carlosking450 said: Hola otra vez ahora os escribo en español,lo primero gracias por vuestro interes.He visto aqui en España las ruedas de las fotos son completamente nuevas y la medida es la original 6.00-12 para mi wheel horse 702.Pero a simple vista tengo la senasacion de que el taco o dibujo de la rueda es muy alto y tengo miedo de que la rueda choque contra el cubre rueda. Here is the translation Hi again now I write you in Spanish, first thanks for your interest.I have seen here in Spain the wheels of the photos are completely new and the measurement is the original 6.00-12 for my wheel horse 702.But at first glance I have the senaing that the block or drawing of the wheel is very high and I am afraid that the wheel crash against the wheel covers. Share this post Link to post Share on other sites
carlosking450 161 #12 Posted August 30, 2017 21 hours ago, wheelhorseman said: Acabo de poner nuevos neumáticos 6-12 en mi 702. Aquí está una imagen y un acoplamiento para la referencia así que usted puede conseguir los correctos allí. Https://m.summitracing.com/parts/crr-5233c3 Quieres decir medida 6.00-12 verdad? Share this post Link to post Share on other sites
ol550 863 #13 Posted August 31, 2017 (edited) 6-12 no es el mismo tamano neumatico que 6.00-12. El 6-12 sera mas pequeno. Edited August 31, 2017 by ol550 Share this post Link to post Share on other sites
carlosking450 161 #14 Posted August 31, 2017 Hola de nuevo,se que son 6.00-12 yo me referia a la medida de WHEELHORSEMAN en su 702 que segun el monto 6-12 Share this post Link to post Share on other sites
