mikeystones 0 #1 Posted August 29, 2017 Installing a new motor on my 312-8 need to remove pto pulley from old motor anyone have any tricks For getting it of the main shaft? Share this post Link to post Share on other sites
N3PUY 1,031 #2 Posted August 29, 2017 Remove the set screws 1 Share this post Link to post Share on other sites
ericj 1,579 #3 Posted August 29, 2017 set screws and use a steering wheel puller to pull it. might have to buy longer bolts to get the job done eric j 1 Share this post Link to post Share on other sites
R. L. Addison 299 #4 Posted August 29, 2017 I had one on a C141 that i broke several 1/4" bolts trying to pull, and finally wound up using 1/2" coupling nuts with 1/2" set screws with 17/64" holes drilled in them and pulled against 1/4" SHCS (allen head bolts {grade 8 standard}) and I won the argument, as this set-up broke loose the roots that had grown over a period of almost thirty years and the pulley yielded to my wishes. I enjoy challenges, and will post pictures of some of my solutions when I can become a supporter. 1 Share this post Link to post Share on other sites
Texas Todd 1,025 #5 Posted August 29, 2017 Make up your own penetrating oil with 50/50 acetone and ATF. Works better and cheaper. Give it a douse with a pump oiler the night before. Share this post Link to post Share on other sites
