shunter 20 #1 Posted August 27, 2017 Put a new battery in my charger 12 and now the lights do not t work, they did before the change. where should i begin to see whats wrong, is there a fuse i cant see? Share this post Link to post Share on other sites
AMC RULES 37,192 #2 Posted August 27, 2017 Probably the ground needs cleaned... light switch on, wiggle the hood around...see what happens. 4 Share this post Link to post Share on other sites
SylvanLakeWH 28,141 #3 Posted August 27, 2017 Same thing to me last year...New ground and boom - lights work perfect... 1 Share this post Link to post Share on other sites
953 nut 59,358 #4 Posted August 27, 2017 Here is the manual with wiring diagrams, happy hunting. With any electrical problem I have always found that cleaning and tightening all electrical connections will cure most of them. 2 Share this post Link to post Share on other sites
N3PUY 1,031 #5 Posted August 27, 2017 Was there a single wire for the lights to the battery that didn't get reconnected? Share this post Link to post Share on other sites
shunter 20 #6 Posted August 28, 2017 Thanks for all the input, it ended up being the contacts on the light switch, go figure.. not that i use them, they are not to bright.. has anyone ever retro'd LED's bulbs? 1 Share this post Link to post Share on other sites
AMC RULES 37,192 #7 Posted August 28, 2017 If you take the time to replace your lens, & detail that light bucket... I think, you'd be surprised how bright them old 1156's really are. 3 Share this post Link to post Share on other sites
shunter 20 #8 Posted August 28, 2017 Nice work there, i'll give it a shot, what did you use on the lens? 2 Share this post Link to post Share on other sites
AMC RULES 37,192 #9 Posted August 28, 2017 New lens... & a liberal application this on the bucket, sockets, springs, contacts. 1 Share this post Link to post Share on other sites
Sarge 3,464 #10 Posted August 30, 2017 There are some pretty high powered led conversion bulbs that will fit the 1156 socket base - they aren't cheap but will provide about a 200% boost in output at a lower draw rate . Not sure how long they will last as the chips need to dissipate the heat - might need some vent holes in the housing . I had a set in an old car - they were a bit overkill but at least you could see backing up at night . Sarge 1 Share this post Link to post Share on other sites
