dkg520 523 #1 Posted August 27, 2017 I need some opinions on which is the best fluid to run in my 1975 C160 8 speed transmission. Thank you in advance Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,272 #2 Posted August 27, 2017 The info from the lube chart has been copied to this page. Click on the Tractor 1975 C-160 OM Wiring.pdf line below. Then click on the small pictures and they will enlarge. Garry 1 Share this post Link to post Share on other sites
pfrederi 18,378 #3 Posted August 27, 2017 Clean with no water added WH changed recommendations over the years. My L107 has faithfully run for 50 years now with no issues using 40w motor oil. Others have run equally well with 90w some have 85-140. If you have money to burn I am sure they will also work well with Synthetic. Share this post Link to post Share on other sites
