12 hp Kohler 1,020 #1 Posted August 27, 2017 Hi, I need three one inch axle seals for my wheel horses and wondering where you get them because I can’t find the and where. Does any one have any links or website names for me to try, thanks for any info in advance Share this post Link to post Share on other sites
Anglo Traction 761 #2 Posted August 27, 2017 Search the Web for these Oil Seal numbers - Wheel Horse Part # 100863 or Motion Ind 01295997 or SKF 9815 . Plenty out there. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,166 #3 Posted August 27, 2017 Have a local Napa store? They supply SKF seals which used to be Chicago Rawhide and use the same numbering system. Garry 2 Share this post Link to post Share on other sites
953 nut 65,344 #4 Posted August 27, 2017 This PDF has all the numbers you will ever need. 1-6&8 speed UNI DRIVE TRANS.pdf 2 Share this post Link to post Share on other sites
12 hp Kohler 1,020 #5 Posted August 27, 2017 Ok, thanks for info ! Share this post Link to post Share on other sites
12 hp Kohler 1,020 #6 Posted August 27, 2017 Does this look like it would fit ? Share this post Link to post Share on other sites
pfrederi 20,306 #7 Posted August 27, 2017 That is the one. Look around with that # better prices can be had. 2 Share this post Link to post Share on other sites
12 hp Kohler 1,020 #8 Posted August 27, 2017 (edited) Ok, thanks, Does this look right there is know item description so I am not sure if it’s the right size or not, if it is though price seems pretty good, what do you guys think Edited August 27, 2017 by 12 hp Kohler Share this post Link to post Share on other sites
