Skipper 1,790 #1 Posted August 25, 2017 Hi A word of advise offered, and a bit of info wanted please. Today while mowing with my C-120, it suddenly gave a rather loud pop, not quite like a shotgun, but close to it. I saw parts flying off the tractor. I stopped, listened, and could not hear anything wrong with the engine. Looked closer and i saw the top af the battery was blown right off. Newer seen that before! So I stopped the engine and rinsed the tractor down with water. Luckily I dit not get sprayed. So I found another battery, started it up, and checked the charging. 15.8V. Well that explained it, so now I know the voltage regulator is not good. So my warning to you all is, if your battery is out in the open, check if it over charges. I can't help thinking, what if my kids had been next to it.................... So aside with the melodrama, and here goes the question. A voltage regulator for a C-120 is next to impossible to find her, so would I be able to source one from any old tractor. Briggs powered or what not? Or do I have to ground the horse till I can find a spare in the US? 1 1 Share this post Link to post Share on other sites
Lee1977 7,364 #2 Posted August 25, 2017 (edited) You can use the same type regulator rectifier that is on a Magnum, the mounting will be different. You can find them on Ebay at a reasonable price. Before you buy one check your grounds. A bad ground can cause the voltage to be up. Partstree list the same type as yours but at $193 I don't think you will want one. Edited August 25, 2017 by Lee1977 4 Share this post Link to post Share on other sites
953 nut 61,823 #3 Posted August 25, 2017 1 hour ago, Lee1977 said: A bad ground can cause the voltage to be up 3 Share this post Link to post Share on other sites
Shuboxlover 481 #4 Posted August 26, 2017 Had that happen to me while I was snow blowing years ago....and this was right after I just restored the tractor. I gave it a good bath with the hose in 15 degree weather, left it outside so it wouldn't drip in the garage...ONE BIG ICE CUBE in the morning. 1 1 Share this post Link to post Share on other sites
pacer 3,177 #5 Posted August 26, 2017 19 minutes ago, Shuboxlover said: .ONE BIG ICE CUBE in the morning. Heh!, no doubt, but.... what choice did you have? that acid HAD to be diluted. 2 Share this post Link to post Share on other sites
Achto 29,750 #6 Posted August 27, 2017 On 8/25/2017 at 5:20 PM, Skipper said: A voltage regulator for a C-120 is next to impossible to find her, so would I be able to source one from any old tractor. Briggs powered or what not? Or do I have to ground the horse till I can find a spare in the US? I do not know their over seas shipping prices but you can find an A.M. regulator on this site for around $30 US. http://www.psep.biz/store/kohler_voltage_regulator.htm 1 1 Share this post Link to post Share on other sites
GREYGHOST 65 #7 Posted August 28, 2017 I'm unfamiliar with your Tractor but these folks have been able to help me with old parts in the past. Replacement Parts 1-888-346-4815. Good Luck Brent 1 Share this post Link to post Share on other sites
Skipper 1,790 #8 Posted August 28, 2017 So, I cleaned the regulator, checked connections, made a second 100% grounding, and still it goes up. Today it went to almost 17V, so I'm also grounded till a replacement can find it's way here Thanks for all the advise and help ! 1 1 Share this post Link to post Share on other sites
TDF5G 2,073 #9 Posted August 29, 2017 On 8/25/2017 at 5:43 PM, Lee1977 said: Partstree list the same type as yours but at $193 I don't think you will want one. Holy Voltage, Batman! That's insane. 2 Share this post Link to post Share on other sites
rmaynard 16,526 #10 Posted August 29, 2017 (edited) I don't know what their overseas shipping rates are, but a replacement regulator from Milford Power is an option. http://www.milfordpower.com/R10297-Voltage-Regulator-Replaces-Kohler-41-403-06-p/r10297.htm Oops, no international shipping available. Edited August 29, 2017 by rmaynard 1 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,699 #11 Posted September 18, 2017 This is from a Stens dealer in Canada. They told me a few years ago they would ship to Europe. https://www.bantasaw.com/catalog/viewproduct.asp?i=&p=6309 Garry 2 Share this post Link to post Share on other sites
Skipper 1,790 #12 Posted September 18, 2017 I have taken a chance I have a used coming from the US, and I have ordered this, as a tester: https://www.aliexpress.com/item/Voltage-Regulator-Rectifier-For-Kohler-8-25-HP-Engine-41-403-10-S-41-403-09/32818205519.html?spm=2114.search0104.3.24.NadeGz&ws_ab_test=searchweb0_0,searchweb201602_2_10152_10065_10151_10068_10344_10342_10343_10340_10341_10304_10307_10137_10060_10302_10155_10154_10056_10055_10054_5470020_10059_100031_10099_5460020_10338_10339_10103_10102_440_10052_10053_10142_10107_10050_10051_5380020_10171_10326_10084_10083_10080_10082_10081_10110_10111_10112_10113_10114_143_10312_10313_10314_10078_10079_10073-10102,searchweb201603_6,ppcSwitch_4&btsid=82eb546b-f660-47b3-8efc-259449dabaec&algo_expid=8aaa63b5-045b-44b9-b5fc-4aa2ea841d22-3&algo_pvid=8aaa63b5-045b-44b9-b5fc-4aa2ea841d22 It should be a replacement part, where only the connector needs a bit of redoing. Lets see if it works 1 Share this post Link to post Share on other sites
Skipper 1,790 #13 Posted September 30, 2017 OK, so the china 8 buck + change including freight regulator came in last week. It was really easy to mount. Clear markings, actually the exact same markings as on the other wise identical units that are supposed to be "not china made". To me they look exactly the same................. Not just sort of, but 100% exactly the same, on the outside anyway. I can not see the hardware inside, so I can not be 100% sure, but my gut tells me this is the exact same product, as the much more expensive "originals", which I guess is probably made at the same factory, but probably in the weekends . Just my guess of cause. Well did it work? Yup. It took 5 minutes, and now it charges with precisely 14,2v. No less, no more. Will it last as long as if I had paid a fortune for an original? Well your guess is as good as mine............... 2 Share this post Link to post Share on other sites
953 nut 61,823 #14 Posted October 1, 2017 1 hour ago, Skipper said: took 5 minutes, and now it charges with precisely 14,2v 1 Share this post Link to post Share on other sites
