valleyboy 1 #1 Posted August 21, 2017 Is removing axel seals and replacing them difficult? Problems with worn key slot in hub. If having slot relocating In different location the set screw would not have as much metal depth? Is this a problem? better to find good used. Share this post Link to post Share on other sites
pfrederi 19,131 #2 Posted August 21, 2017 The hard part of seals is getting the hubs off...Guess you have that done. If the keyway in the hub is compromised I would get a replacement. Check our vendors here like A to Z 2 Share this post Link to post Share on other sites
