mission x3 4 #1 Posted August 18, 2017 i was mowing on my wheel horse c 140 8 speed when i finally pushed the clutch in the last time and let it out in gear and the tractor would not move, i can visually see the belt spinning and the pulley on the side of the transmission spinning. the shifter will go in and out of all gears high and low r-3 on both settings, in neutral i can push it fine like nothing is catching. i am not sure if this has anything to do with it but about a half hr before the mower stopped driving i was about to go over a steep bank and i hit the break in stead of pushing in the clutch and the brake, after that it seemed when i would shift and let the clutch out it was like it wasn't engaging and then when it did it jumped and then would go, anybody else have this problem, or any ideas of something to check, when i was trying to get it in my garage i put it in first and you can almost push it along and its like it wants to go but just doesn't have enough to get it driving on its own. Share this post Link to post Share on other sites
Ed Kennell 45,021 #2 Posted August 18, 2017 Check the key in the transmission drive pulley. The pulley may be turning, but not the shaft. 7 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #3 Posted August 18, 2017 Also check both wheel hubs to see if one of the axles is spinning inside the hub. There are keys in them as well as the input pulley. It only takes one of the three to fail and no drive. Garry 7 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #4 Posted August 18, 2017 @mission x3 to Both above answers are possibilities. Please let us know what the problem was. Share this post Link to post Share on other sites
953 nut 64,277 #5 Posted August 18, 2017 Looks like you have gotten some good advice. You can buy a replacement woodruff key at any good hardware or auto parts store, just take the pieces of the old one in so they can match it up. Share this post Link to post Share on other sites
Digger 66 3,525 #6 Posted August 18, 2017 Welcome fellow NY'er . 1 Share this post Link to post Share on other sites
mission x3 4 #7 Posted August 19, 2017 Thank you guys for your help it was the key on the left tire was just about all the way out and I watched it when I put it in gear and that shaft just spun with the tire not moving, thank you!! 2 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #8 Posted August 19, 2017 Do you really have an original C-140 8-speed? Thought they were only a European model. Interested in knowing what the model number and serial number are. Wanted to look up the correct part numbers for you. Garry 1 Share this post Link to post Share on other sites
mission x3 4 #9 Posted August 20, 2017 well i being new at wheel horse saw the c141 on the hood and that it had a 14hp engine that then it was a c141, but i am thinking at some point someone maybe put this hood and engine on another body/frame being after i looked up the model number on the frame being 81-14k801-09030, so do the first two numbers on the model say what model it is? so is it a c81? and how do you tell if a wheel horse is a A B or C? Share this post Link to post Share on other sites
953 nut 64,277 #10 Posted August 20, 2017 This list will help you find the proper information. wheelhorseallyears.pdf 1 Share this post Link to post Share on other sites
mission x3 4 #11 Posted August 21, 2017 Okay that's great so yes the model number on there does match and so then I do have a c141 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,014 #12 Posted August 21, 2017 Garry 1 Share this post Link to post Share on other sites
