Randy Huffman 1 #1 Posted August 13, 2017 Can anyone tell me how the spring and thrust bearings are positioned in a C-160 pto? Mine was in pieces when I took it apart to replace the outer bearing. Share this post Link to post Share on other sites
KC9KAS 4,744 #2 Posted August 14, 2017 @Randy Huffman to Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,774 #3 Posted August 14, 2017 If you replace the outer stub shaft the bearing is on with a later version that uses a snap ring on each side of the bearing you can eliminate all the inner pieces. This allows the bearing to pull the pto hub out when in the OFF position rather than the inner bits pushing it out. Item 33 is the stub shaft and 34 are the two snap rings required. http://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/31-12k801-312-8-toro-312-8-garden-tractor-1990/pto-clutch-and-control/ The original inner pieces http://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/71-16ks02-c-160-toro-c-160-automatic-tractor-1977/pto-clutch-and-controls/ Garry Share this post Link to post Share on other sites
Randy Huffman 1 #4 Posted August 14, 2017 Great, thank you. I unfortunately did order a new stub shaft but it's probably the old style since I went by the Mod./SN but I know what to get now. Thank you! Should have joined up sooner. Just found the Red Square sight. 1 Share this post Link to post Share on other sites
Sarge 3,470 #5 Posted August 15, 2017 I'm not too far away from you in Ohio south of Dixon if you need help . These things are pretty simple and very tough , download the manual for yours in the manual section and go at it .... Sarge Share this post Link to post Share on other sites
