Cape Codder 5 #1 Posted August 13, 2017 Hi, I'm the new owner of a 1990 Toro Wheel Horse 310-8. Great condition with 37" side discharge and bagger. The machine has just been gone through and is running great. The question I have is that 2nd speed in high gear is a little slow for mowing and 3rd is rather fast. I could throttle 3rd down but the machine when cutting is recommended at full throttle for a good cut. Any help on this. 1 Share this post Link to post Share on other sites
stevasaurus 23,617 #2 Posted August 13, 2017 That is one of those things we all deal with. Not too much you can do...make sure you have sharp blades and/or cut the grass more often. Don't let it get so long that you need 2nd gear. If you don't have one, put on a cup holder and enjoy the ride. Welcome to Red Square!!! 4 3 2 Share this post Link to post Share on other sites
Ed Kennell 44,942 #3 Posted August 13, 2017 Do not throttle down to use 3rd. The blades need to spin at designed RPM to achieve the lift for a proper cut. You could possibly switch to a smaller transmission input pulley to increase the ground speed. You may be able to decrease the dia. slightly 1/2" max , and not affect the clutch and belt function. Any more than 1/2" dia decrease will require a shorter belt and would probably cause problems getting the belt to stop for smooth gear changing. 2 1 Share this post Link to post Share on other sites
Racinbob 12,779 #4 Posted August 13, 2017 I agree that 2nd is a tad too slow and 3rd is too fast. I have heard that some folks replace the engine drive pulley with one from a hydro since it's larger. I've never done that and I don't know how much of an increase you'd get but at least a little. Share this post Link to post Share on other sites
ericj 1,579 #5 Posted August 13, 2017 I did replace the engine drive pulley on a 416-8 that I re-powered with an 18 hp onan with the hydro pulley. I was a little difficult to find a correct belt to fit and you can smell it burning every once and awhile. 3 gear is definitely faster. the rest of the gears are close to the same. 2nd gear maybe a little faster and seems to make some difference. this is why I kinda prefer to mow with a hydro although my problem is with a hydro I go to fast and like the better quality of cut I get with a gear drive. eric j 2 Share this post Link to post Share on other sites
Ed Kennell 44,942 #6 Posted August 13, 2017 Copy that Eric. You know I only use Hydros...and with foot control and hydraulic lift. I am constantly changing speeds and direction and lifting the deck while mowing around trees, tree roots, and buildings. 1 Share this post Link to post Share on other sites
953 nut 64,158 #7 Posted August 13, 2017 I just mow in second gear and enjoy the extra seat time on my 310-8. Lower RPMs will not give the mower a proper blade tip speed and will not provide enough engine cooling. If you need to cut your mowing time you may want to consider a 42" deck, the 310 will handle it just fine. 2 Share this post Link to post Share on other sites
dcrage 631 #8 Posted August 13, 2017 You guys must have pool tables for lawns. I have never been on a surface that I would cut in 3rd high. Seriously were our tractors & decks designed to cut at those speeds? I would think 8 mph is kinda fast and my 37" would not cut that well at that speed. Aren't we trying to impose Zero Turn performance onto our tractors? 5 1 Share this post Link to post Share on other sites
SylvanLakeWH 30,601 #9 Posted August 13, 2017 2nd gear + cup holder + Beverage of choice + noise reduction ear muffs + smell of fresh cut grass = Heaven... Unless you are a commercial operation focussed on production - enjoy the seat time... 8 2 Share this post Link to post Share on other sites
608KEB 812 #10 Posted August 13, 2017 I always thought gear 1 1/2 would be a good speed. My lawn isn't that flat. 1 Share this post Link to post Share on other sites
Tractor boy 239 #11 Posted August 13, 2017 Did you try third low? Share this post Link to post Share on other sites
dcrage 631 #12 Posted August 13, 2017 3rd low is slower than 1st high. Speeds increase in order from 1st low to 3rd high. 2 Share this post Link to post Share on other sites
608KEB 812 #13 Posted August 14, 2017 2 hours ago, 608KEB said: I always thought gear 1 1/2 would be a good speed. My lawn isn't that flat. What I'm saying is the speed between 1 and 2 when in high range. That'd be perfect for me. Share this post Link to post Share on other sites
Ed Kennell 44,942 #14 Posted August 14, 2017 The only 8 speed I use for mowing is a Raider 12 with a 42" SD deck. I use it to mow the 500' x 20' right of way. High - second is almost too fast. High - third would turn your kidneys inside out. 1 1 Share this post Link to post Share on other sites
JC 1965 1,541 #15 Posted August 14, 2017 I cut my grass in 2nd gear with 312-8 and 42" deck. I get a better cut that way. 5 1 Share this post Link to post Share on other sites
Molon_Labe 731 #16 Posted August 14, 2017 I'm in the minority on this one for sure. I mow in 1st gear with my C-101 with the 42RD deck. Second is way too fast, too many back surgeries for the bumps and jolts of the higher speeds. I do wish that 1st gear was the same ratio as reverse, that would be about perfect. 5 Share this post Link to post Share on other sites
jackhammer 550 #17 Posted August 14, 2017 I use 1st gear for my 1/2 acre a 312 42 sd with a vac bagger,,, Rick 2 Share this post Link to post Share on other sites
TDF5G 2,073 #18 Posted August 14, 2017 Full throttle high range in 2nd gear. I run 1st gear along the ditch or tricky spots. 3rd gear is too fast for bumps, it doesn't leave a nice cut. My dad mows in 3rd gear usually and the results are poor IMO. If I'm gonna put in the effort to mow, I prefer it to look good when I'm done, not have it look like it needs mowing again. 4 Share this post Link to post Share on other sites
rayshorses 102 #19 Posted August 15, 2017 I mow over an acre of smooth flat lawn with the c-160-48" deck. 2nd gear works fine even in thick grass , but 1st gear high range is my favorite gear. I like to watch the clippings flow out of the discharge and the seat time is the only time i get to relax . I usually grin ear to ear the whole time. Over 40 years of memories with my Wheelhorses come back to me every time i drive it. 8 2 Share this post Link to post Share on other sites
P3x 60 #20 Posted August 16, 2017 I have aRrecycler deck mounted on my 310-8. Have the deck set at its highest setting and have to use 1st High to get the best cut.Painfully slow... Use 2nd gear if only if in a rush (rain coming). In 2nd seems to miss a lot especially in turns no mater how gradual. Figure it may be due to going too fast is not allowing the grass blades to straighten out after going under the front tires/deck compounded by the deck losing vacuum effect set at its highest position. Don't remember having the same cutting issues when using 42/48 SD decks, but like the idea of recycling grass clippings. After the summer heat going to try lowering the deck a few notches and see how it cuts in 2nd. 1 Share this post Link to post Share on other sites
pfrederi 19,930 #21 Posted August 16, 2017 My primary mowers are a 418A with a foot control and a C175 8 speed both with 48SD decks. Favorite is C175 2nd gear...Like the old Ron Popiel TV infomercials said "Set it and Forget it" Up or down steep hills into heavy grass whatever no changes Share this post Link to post Share on other sites
