cafoose 3,499 #1 Posted August 11, 2017 (edited) Does anyone know where I can locate a spacer for a bolt in the deck of my 520-HC? I checked Lowes and hardware stores and can't find the right size. Number 3 in the diagram. Looks like 5/8 OD x 3/8 ID x 5/16 long. Edited August 11, 2017 by cafoose Share this post Link to post Share on other sites
JPWH 6,541 #2 Posted August 11, 2017 TSC you may or may not find the exact length but you can cut it. 1 Share this post Link to post Share on other sites
cafoose 3,499 #3 Posted August 11, 2017 1 hour ago, JPWH said: TSC you may or may not find the exact length but you can cut it. I checked TSC they don't have the right diameters Share this post Link to post Share on other sites
tunahead72 2,581 #4 Posted August 11, 2017 McMaster-Carr? Share this post Link to post Share on other sites
cleat 7,705 #5 Posted August 11, 2017 I get all of my parts here. http://www.mowerpartpros.com/OEMpartfinder.htm#/s/TO/15-48SC03,_48"_Side_Discharge_Mower,_1992_(SN_2000001-2999999)//1 http://www.mowerpartpros.com/OEMpartfinder.htm#/Toro_Consumer/15-48SC03,_48"_Side_Discharge_Mower,_1992_(SN_2000001-2999999)/SUSPENSION_ASSEMBLY/15-48SC03-19852-1992/3314-842-|~8420006-0003 Spacer you need is $1.00 (plus shipping). Cleat Share this post Link to post Share on other sites
N3PUY 1,031 #6 Posted August 11, 2017 (edited) I've got those at my local WH dealer. What's wrong with the one you have? Edited August 11, 2017 by N3PUY Share this post Link to post Share on other sites
Ed Kennell 43,173 #7 Posted August 11, 2017 I may have some. I'll check this AM. Share this post Link to post Share on other sites
Ed Kennell 43,173 #8 Posted August 11, 2017 Yep, I have them. Share this post Link to post Share on other sites
cafoose 3,499 #9 Posted August 12, 2017 I checked here in Jacobus, PA just 10 miles from me and I got four of them and a carriage bolt for just under 6 bucks: http://www.innerstsalesandservice.com/ Everyone for your help, I cleaned under the deck, sharpened the blades, torqued the spindle and blade nuts to 80 to 100 ft lbs, and greased the spindles. All I need to do yet is put the carriage bolts on and install the deck. I also checked the spindles for wear and freedom of movement and put on a new green belt from NAPA and it all looks good. 12 hours ago, N3PUY said: I've got those at my local WH dealer. What's wrong with the one you have? One was missing I guess a PO lost it and installed the bolt without it which wore the bolt thin and also made everything sloppy. 10 hours ago, Ed Kennell said: Yep, I have them. Ed I got them here: http://www.innerstsalesandservice.com/ Share this post Link to post Share on other sites
