Rough Cut 25 #1 Posted August 8, 2017 My Amazon store card took a $450 hit today... New throttle and choke cables. New carb. New tri ribs for the front and 4 rear ag tires. So that has me curious of the dual wheel setup that folks are using. I have been thinking of getting another set of wheels and cutting the centers out altogether. Then using carriage bolts and make up some black iron sleeves and bolting them where the wheel weights would bolt. Has anyone done this? My father in law has an old wheel horse that he did duals on. No idea his setup. But he warned me that they wore the key ways out on his. He blames the duals. They used theirs for pushing snow and dirt. Pulling a disk. Mine is primarily going to be a parade/ show piece. Should I be concerned about the dual wheel setup? Thanks in advance. Share this post Link to post Share on other sites
AMC RULES 37,259 #2 Posted August 8, 2017 (edited) Pretty sure Jason has an original set of these DMI rims... might be able to expound some more, & post up a pict of the set he has for you. Edited August 8, 2017 by AMC RULES 3 Share this post Link to post Share on other sites
953 nut 66,635 #3 Posted August 8, 2017 If you want to save a lot of aggravation you could go on the website of Wheelhorse Parts and More and buy a pair of adapters already made up or you can make them, here is the info. Dual Wheel Adapter dwg.pdf 4 hours ago, Rough Cut said: warned me that they wore the key ways out on his. One thing that should be done with dual wheels is to keep the tire pressure in the outer tires very low, this will reduce the axle problems. 2 Share this post Link to post Share on other sites
Achto 31,906 #4 Posted August 8, 2017 http://www.wheelhorseforum.com/applications/core/interface/file/attachment.php?id=131998 A warning with this drawing. The dimensions are off for some rims. Measure the distance between the mounting holes & adjust if nessasary. 2 Share this post Link to post Share on other sites
"D"- Man 827 #5 Posted August 8, 2017 You may want to consider extended axles and a second pair of hubs. A fellow Redsquare made a pair for me and had them magnetic induction heat treated. 4 Share this post Link to post Share on other sites
R. L. Addison 300 #6 Posted August 8, 2017 Would "D" axles be long enough for "B" or "C" duals? Share this post Link to post Share on other sites
WHX?? 56,851 #7 Posted August 8, 2017 8 hours ago, Rough Cut said: warned me that they wore the key ways out on his. He blames the duals Make sure the setscrews are kept tight along with low pressure in the outer tires as mentioned. Adding another setscrew to the hubs is easily done for further keyway protection. 1 Share this post Link to post Share on other sites
CasualObserver 3,416 #8 Posted August 8, 2017 @AMC RULES Craig is right, I do have some of these very hard to find DMI mini-duals. I won't repeat the DMI story from the link above, but here are the pics I have available. When I got them..... And from when I had them mounted one time. I was thinking of getting them out for a show in a few weeks... if I do, I'll get some new (hopefully better) pictures. 2 Share this post Link to post Share on other sites
WHX?? 56,851 #9 Posted August 8, 2017 34 minutes ago, CasualObserver said: for a show in a few weeks... Pioneer Power?!?!? Share this post Link to post Share on other sites
FatJackDurham 318 #10 Posted August 8, 2017 What is the purpose of dualies other than looks? I can see on a long shaft with a second hub it might help spread weight out on soft ground, and for me it might keep it from rolling sideways, but would four bolts be enough to hold it if you didn't have the long axle? Share this post Link to post Share on other sites
AMC RULES 37,259 #11 Posted August 8, 2017 Sure, it's enough...when you consider the bolts and the spacer that is built into them... takes up the space between the two, & slips into the rim you have mounted to the hub. 1 Share this post Link to post Share on other sites
Rough Cut 25 #12 Posted August 10, 2017 On 8/8/2017 at 6:14 AM, AMC RULES said: Pretty sure Jason has an original set of these DMI rims... might be able to expound some more, & post up a pict of the set he has for you. I really like this. Ups man brought some goodies.... 2 Share this post Link to post Share on other sites
AMC RULES 37,259 #13 Posted August 10, 2017 Check out post #46 here in this old thread... 2 Share this post Link to post Share on other sites
