Searcher60 209 #1 Posted August 6, 2017 Picked up a 1997 520 with some wiring issues. The engine harness main wiring connector plugs have been cut out. Anywhere I can buy both male and female plugs with the proper wiring connectors? Thanks in advance. Share this post Link to post Share on other sites
roadapples 6,985 #2 Posted August 6, 2017 Contact Bob's wheel horse linings and more in the vender section... 1 Share this post Link to post Share on other sites
Searcher60 209 #3 Posted August 6, 2017 48 minutes ago, roadapples said: Contact Bob's wheel horse linings and more in the vender section... Many thanks to you! 1 Share this post Link to post Share on other sites
cleat 8,054 #4 Posted August 6, 2017 Much as I love to support our vendors, I bought sealed versions of the original 9 pin connectors from ebay. They came from Europe but shipping was reasonable. They are the exact same connectors but come with rubber seals for where the wires pass through and also a rubber gasket for between the connectors. Cleat 1 Share this post Link to post Share on other sites
Searcher60 209 #5 Posted August 6, 2017 23 minutes ago, cleat said: Much as I love to support our vendors, I bought sealed versions of the original 9 pin connectors from ebay. They came from Europe but shipping was reasonable. They are the exact same connectors but come with rubber seals for where the wires pass through and also a rubber gasket for between the connectors. Cleat I cannot find that connector out of over 9000. Can you message me the eBay seller or link? Links not allowed in forum. Thanks Share this post Link to post Share on other sites
lynnmor 8,252 #6 Posted August 6, 2017 I would like a link to that connector as well. Even with the weatherproof design, I would run an jumper around the charge wire to help carry the heavy load. Share this post Link to post Share on other sites
