tallen4392 71 #1 Posted August 2, 2017 Anyone have any tips to remove the shifter knob off of a c series tractor will not move ..... thanks thanks i found some info on here i can try Share this post Link to post Share on other sites
daveoman1966 3,880 #2 Posted August 2, 2017 Maybe a STRAP WRENCH. or.... wrap several rounds of good DUCT TAPE ...the large Channellock pliers.....so you can get a good grip, without breaking the shift knob. 1 Share this post Link to post Share on other sites
stevasaurus 23,483 #3 Posted August 2, 2017 leather strips wrapped around the know will keep it from getting scratched...then use channel locks. 1 Share this post Link to post Share on other sites
953 nut 62,514 #4 Posted August 2, 2017 2 minutes ago, stevasaurus said: leather strips wrapped around the know will keep it from getting scratched...then use channel locks. I would suggest you use a small pipe wrench on the shift lever while you are turning the shift knob; pulling the two toward each other so the shift lever isn't being torqued. 7 Share this post Link to post Share on other sites
tallen4392 71 #5 Posted August 4, 2017 I found a nice way to help remove those shifter knobs I took 1/8 inch drill bit drilled a small hole through the center of the knob and kept letting penetrate oil seep through after a while a rag and channel locks came right off I drilled until I hit metal then put a new decal on the knob to cover the hole if it bothers you 1 Share this post Link to post Share on other sites
GlenPettit 1,718 #6 Posted August 4, 2017 "Expansion-Contraction": Much easier to let physics work with us, remove when it's cool (early morning), or cool down the knob & lever somehow, and using the above suggestions. The insert that is inside the knob ball is probably Brass, which helps hold it on the shift lever, but a slow steady turning force should allow it to loosen/give. Good Luck, 2 Share this post Link to post Share on other sites
