Chrisprk 1 #1 Posted July 30, 2017 Circuit board went bad and don't want to pay out for new board or repair. I've been told few different ways to wire up but seems simplest way is to hook wire from battery terminal on key switch to fuse box. Fuse box has two open slots a male slot and female slot and need to know which slot I should hook wire to and where to route black ground wire or can anyone tell me how to wire it to keep charging system hooked up.i want to make this wheel horse run but don't know anything about bypassing safety switch circuit boards. This tractor was running like a champ til the battery kept going dead so I replaced the battery with new one the same size then I turned key one notch and it blew the safety switch light circuit board on the dash can anyone walk me through the steps to bypass the board Share this post Link to post Share on other sites
SylvanLakeWH 30,519 #2 Posted July 30, 2017 Some of the electrical wizards will be along to provide input.... 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #3 Posted July 30, 2017 From past interest on the subject it was determined the board can be simply removed. The tractor will operate as normal. It was also determined the original board was replaced by different versions and the last would work in place of the first. I would be checking the tractor wiring circuit by circuit to make sure it is not the cause of the fault. We should have diagrams specific to your model whatever it is. May be of interest Garry Share this post Link to post Share on other sites
Chrisprk 1 #4 Posted July 31, 2017 Where does the red wire coming from battery terminal on key switch need to be hooked to in order to bypass the circuit board Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #5 Posted August 1, 2017 That red wire powers the circuit board only so no need to do anything with it. Garry 1 Share this post Link to post Share on other sites
Chrisprk 1 #6 Posted August 1, 2017 Ok I have a black wire with a round end on it coming from the center of the back of the hour meter.is this a ground wire ? Does it need to be hooked back to the board bracket that holds the board to the dash? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #7 Posted August 1, 2017 I would say yes. The wiring diagram shows a ground wire to the chassis metal from the hour meter - looks like an arrow made up of horizontal lines. Garry Share this post Link to post Share on other sites
Chrisprk 1 #8 Posted August 2, 2017 On 8/1/2017 at 5:30 AM, gwest_ca said: I would say yes. The wiring diagram shows a ground wire to the chassis metal from the hour meter - looks like an arrow made up of horizontal lines. Garry Ok what do I do with all other wires that came off circuit board Share this post Link to post Share on other sites
Chrisprk 1 #9 Posted August 3, 2017 Ok can tell me what I need to do with wires from circuit board.the board has been removed from Tracy or the ground has been grounded back to the board bracket the red wire from the battery terminal on key switch has been unhooked from the board but still hooked to the terminal on switch just need to know how or what to do with other safety switch wires that were unhooked from the board Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,990 #10 Posted August 3, 2017 Don't do anything with them. Just make sure the terminals in the wire holder can not short to the chassis metal. A good application for a wrap of duct tape to cover them. Garry Share this post Link to post Share on other sites
Chrisprk 1 #11 Posted August 4, 2017 Hi gwest_ca I wanted to say you for all your help now my wheel horse is back up and running like new if it wasn't for your help I'd never been able to get this wiring problem solved. I took small engine repair course but they never had enough students to teach the electrical part of the class so therefore I'm having to learn the wiring on my own. So I really learned a lot off you it's great to have someone to teach me their knowledge.thank you again 1 Share this post Link to post Share on other sites
