EricB 0 #1 Posted February 7, 2009 I'm looking for any info. on Sweepster Power Brooms. I need some help mounting mine. If you have any pictures of one mounted on a Wheel Horse tractor that would be very helpful Thank You. Eric in Western, Pa. Share this post Link to post Share on other sites
Teddy da Bear 11 #2 Posted February 7, 2009 :thumbs: Eric! This topic was discussed last fall I believe. Please do a search on the word "sweepster" or "broom" and I think you might see a picture or two. Share this post Link to post Share on other sites
Duff 206 #3 Posted February 7, 2009 Hi, Eric! Check out this link: http://www.wheelhorseforum.com/index.php?...30&hl=sweepster Glad you found us! Duff :thumbs: Share this post Link to post Share on other sites
pfrederi 18,536 #6 Posted February 7, 2009 Mounting is really simple but because of the weight and imbalance it is a bit awkward. I got the front tachmatic hooked first and then used a floor jack to raise the sweepster frame to engage the the mid tach matic mount. The PO used it on pavement so he added the casters to reduce the nose heaviness. (No traction). In my brief test this fall they will not work for my use. I plan on using it to sweep the stones plowed into my front yard by the town plow (and also the stuff I have plowed out on my own driveway. Also I have some instructions for the unit if you PM me I will try to scan them and send them to you...they are not the clearest copies to start with however.... Share this post Link to post Share on other sites
