muz123 1,193 #1 Posted July 28, 2017 (edited) How do i hook up a 40" early model grader blade on a 520H. Cant seem to hook up very easily any advice? Thanks, Dave Edited July 28, 2017 by muz123 Share this post Link to post Share on other sites
953 nut 68,536 #2 Posted July 28, 2017 You will need to run a link or chain from the lift just like the manual tells you. Share this post Link to post Share on other sites
muz123 1,193 #3 Posted July 28, 2017 9 minutes ago, 953 nut said: You will need to run a link or chain from the lift just like the manual tells you. The manual shows a bar not a chain. Share this post Link to post Share on other sites
953 nut 68,536 #4 Posted July 28, 2017 The "BAR" is called a lift "LINK". If you don.t have the link you could use a chain. Share this post Link to post Share on other sites
muz123 1,193 #5 Posted July 28, 2017 (edited) 11 minutes ago, 953 nut said: The "BAR" is called a lift "LINK". If you don.t have the link you could use a chain. Rather not use the chain because i would like down pressure that a chain cannot provide. Will end up creating a custom bar. Edited July 28, 2017 by muz123 1 Share this post Link to post Share on other sites
953 nut 68,536 #6 Posted July 28, 2017 13 minutes ago, muz123 said: end up creating a custom bar. Share this post Link to post Share on other sites
wheelhorseman 3,256 #7 Posted July 28, 2017 I have them if your interested here is a http://wheelhorsepartsandmore.com/brackets-linkages.html#!/Toro-Wheel-Horse-5678-mid-mount-grader-blade-lift-linkage/p/84954675/category=23566571 2 Share this post Link to post Share on other sites
muz123 1,193 #8 Posted July 28, 2017 36 minutes ago, wheelhorseman said: I have them if your interested here is a http://wheelhorsepartsandmore.com/brackets-linkages.html#!/Toro-Wheel-Horse-5678-mid-mount-grader-blade-lift-linkage/p/84954675/category=23566571 Thanks, i have the same bar and tried it. Does not work. Share this post Link to post Share on other sites
wheelhorseman 3,256 #9 Posted July 28, 2017 (edited) Hmmmm interesting what does it hit on? Edited July 28, 2017 by wheelhorseman Share this post Link to post Share on other sites
muz123 1,193 #10 Posted July 29, 2017 39 minutes ago, wheelhorseman said: Hmmmm interesting what does it hit on? Its just to long. Does not hit anything. May be only for older models? Share this post Link to post Share on other sites
953 nut 68,536 #11 Posted July 29, 2017 Have you tried it in different holes on the rocker shaft? 1 Share this post Link to post Share on other sites
muz123 1,193 #12 Posted July 30, 2017 On 7/28/2017 at 8:23 PM, 953 nut said: Have you tried it in different holes on the rocker shaft? Been trying all the holes but haven't found the right spacing of the holes. 1 Share this post Link to post Share on other sites
