erustic 0 #1 Posted July 27, 2017 Hey all, With many experts on this site, I have an early model first year production 520h runs great. I have an opportunity to buy another p220 out of a craftsman gt tractor with 300 hours for 700 complete with starter carb and muffler. Any difference in crankshaft or pto clearance on craftsman onan? Is it worth price or should I look around more to have a spare. Thanks Share this post Link to post Share on other sites
boomers_influence 106 #2 Posted July 27, 2017 erustic please post the spec # from both engines. i should be able to to tell you if they are the same. thank you. boomer ( the used onan engine parts guy, also NOS and new ) Share this post Link to post Share on other sites
erustic 0 #3 Posted July 28, 2017 Spec for the 520h is I/10540b Model and spec. 739. 108968. for craftsman Thank you Share this post Link to post Share on other sites
boomers_influence 106 #4 Posted July 28, 2017 erustic the sears # means NOTHING. i need the actual onan # from the sears. thank you. boomer Share this post Link to post Share on other sites
erustic 0 #5 Posted July 29, 2017 Ok thanks I am working based on cooperation of seller. I will get back if it has not been sold. Thanks. Share this post Link to post Share on other sites
erustic 0 #6 Posted July 29, 2017 It's all I could get Share this post Link to post Share on other sites
ericj 1,580 #7 Posted July 30, 2017 I pulled a motor out of a craftsman 3 series tractor and put it in a wheel horse, unfortunately the boss for the starter mount on the block was broken and I can't keep the starter tight to the flywheel and ended up chewing up the ring gear on the flywheel. once I get someone to figure out how to repair that I'll have it back in a wheel horse. good luck eric j Share this post Link to post Share on other sites
boomers_influence 106 #8 Posted July 30, 2017 erustic the pic tells it all. the sears engine is a 10896 B ( information from the bottom of the tag ) the WH is 10540 B both have the 45 BB crank. ( 1 1/8" X 2.74" usable length ) thank you. boomer Share this post Link to post Share on other sites
