Walhonding520 25 #1 Posted July 23, 2017 Now that it starts and everything else seems fine, it is "surging." From idle all the way to full throttle, the engine seems to rev up and down without touching the throttle. Seems to be less obvious the longer it runs but it still continues? I'm not very good with carbs but I ran a lot of cleaner through it and that helped fit a few minutes but problem persists. Thankd Share this post Link to post Share on other sites
WildHorses 432 #2 Posted July 23, 2017 (edited) Sounds most like a dirty carb, probably need to clean the jets and the bowl. I would also make sure the fuel filter is new/clean and check the fuel line and make sure the fuel tank is clean. Edited July 23, 2017 by WildHorses 1 Share this post Link to post Share on other sites
WildHorses 432 #3 Posted July 23, 2017 You don't want to run carb cleaner through a carburetor without taking it apart btw. Carb cleaner will swell up rubber pieces and make them no longer work properly. Share this post Link to post Share on other sites
Walhonding520 25 #4 Posted July 23, 2017 Nothing through the carb directly. Just sea foam in the fuel. Lines and filter are all new. I guess next step is to just take the carb off and clean it. 2 Share this post Link to post Share on other sites
WildHorses 432 #5 Posted July 23, 2017 I think you can do most of it without taking the carb off as I recall. Take off the air filter housing and the top end of the carb will give you access to the jets. Make sure to close the throttle and the choke in case you drop the screws. Share this post Link to post Share on other sites
cafoose 3,665 #6 Posted July 23, 2017 Check out these threads: Share this post Link to post Share on other sites
daveoman1966 3,882 #7 Posted July 23, 2017 You can take the top off of the carb,...but BE CAREFUL not to drop tiny parts into the throat. FIRST.... clean off al the dirt and crud from the outside surfaces. Take a pic or two of how the linkage goes toegether. Here is the NEEDLE VALVE....it is kinda hidden,so take extra care. Once the top is off, use your carb cleaner and a tiny brush to clean out the float chamber, both sides. 6 Share this post Link to post Share on other sites
lynnmor 8,682 #8 Posted July 23, 2017 Look at the last photo above. Down near the bottom of the carb you will see a welch plug, make sure it is still there. I have had one fall out and it gave the same symptoms you described. As always, check the compression first thing. It may be a good idea to just pull the exhaust, intake, carb, and valve covers and do it right. The exhaust can then be painted, the valves adjusted, the intake checked for sealing and the carb cleaned thoroughly. Intake gaskets, especially cheap ones, can get sucked in causing similar problems, so use real Onan gaskets there. 1 Share this post Link to post Share on other sites
Walhonding520 25 #9 Posted August 3, 2017 So I pulled carb all off and cleaned exhaust as well. It was a real mess. It runs much better now but the governor still surges up and down for the first few minutes it runs. If I throttle it down then it seems to be fine at idle and all the way up again. Is it normal for the governor to do this for a few minutes? 1 Share this post Link to post Share on other sites
lynnmor 8,682 #10 Posted August 3, 2017 Did you adjust the idle mixture screw to get the best idle? The later model carbs are a bit cold blooded. 1 Share this post Link to post Share on other sites
Walhonding520 25 #11 Posted August 3, 2017 So if I adjust the idle screw, the governor should not need to surge for the first few minutes? Share this post Link to post Share on other sites
lynnmor 8,682 #12 Posted August 3, 2017 If it has an idle mixture screw, it should have been removed and cleaner sprayed in the hole. After reassembly, it would need to be adjusted for best idle. The governor cannot work right when the engine does not respond well. Share this post Link to post Share on other sites
Walhonding520 25 #13 Posted August 4, 2017 I did a search for idle mixture screw or adjusting it but nothing popped up. I'm not sure which screw it is or how to adjust it. Ran it a little bit tonight and the tractor runs but surging continues at different times depending on where the throttle is. Share this post Link to post Share on other sites
lynnmor 8,682 #14 Posted August 4, 2017 Download this file:. Onan manual See page 7-1 1 Share this post Link to post Share on other sites
Walhonding520 25 #15 Posted August 5, 2017 Thank you. I am going to get into it this weekend. Is it possible that the spring is to "soft" and won't hold the governor out enough? My neighbor is an old car guy and just suggested it. Share this post Link to post Share on other sites
lynnmor 8,682 #16 Posted August 5, 2017 10 hours ago, Walhonding520 said: Is it possible that the spring is to "soft" and won't hold the governor out enough? My neighbor is an old car guy and just suggested it. I doubt it. Share this post Link to post Share on other sites
Walhonding520 25 #17 Posted August 12, 2017 Ok so I've adjusted what I believe to be the idle screw (spring loaded screw with the head facing the muffler). I don't think the carb could be cleaned anymore. Sometimes the surging or hunting almost goes away but then it comes back. Today while mowing I looked at the fuel filter when it started to act up again and it looked like there was very little fuel in it. Going up air down hills caused it to surge as well. Is it possible that sometimes it's just not getting enough fuel? I'm just looking for something else to try and getting it running smooth. Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,066 #18 Posted August 12, 2017 A slightly different approach but must have been a problem to generate a service bulletin May be the same but has a different service bulletin number Another Garry 1 Share this post Link to post Share on other sites
cleat 8,828 #19 Posted August 12, 2017 I had one of my 520's act up a year or two ago and it turned out to be the fuel line was touching the oil filter and getting hot. A quick relocate of the fuel line and all was well once again. I have also had one hard to start and that was a fuel pump with a short pine tree needle caught up in a check valve (I don't know how it got in there). Cleat 1 Share this post Link to post Share on other sites
Walhonding520 25 #20 Posted August 12, 2017 Thanks again everyone for the fast replies with a variety of options. I'm going to pull each fuel line and valve under fuel tank just to make sore it's all clean. I will post updates. Share this post Link to post Share on other sites
lynnmor 8,682 #21 Posted August 12, 2017 10 hours ago, Walhonding520 said: Ok so I've adjusted what I believe to be the idle screw (spring loaded screw with the head facing the muffler). I don't think the carb could be cleaned anymore. Sometimes the surging or hunting almost goes away but then it comes back. Today while mowing I looked at the fuel filter when it started to act up again and it looked like there was very little fuel in it. Going up air down hills caused it to surge as well. Is it possible that sometimes it's just not getting enough fuel? I'm just looking for something else to try and getting it running smooth. Thanks The air in the fuel filter is normal. Share this post Link to post Share on other sites
Walhonding520 25 #22 Posted August 12, 2017 Ok. Just used tractor for 5 minutes and surging was terrible. However I just noticed that the tank is almost empty and it was getting worse the less fuel there was in the tank as I finished mowing yesterday. So it seems that when fuel gets low, the surging comes back and increases. Any thoughts? Share this post Link to post Share on other sites
ericj 1,579 #23 Posted August 12, 2017 have you cleaned the tank and replace the fuel shut off and fuel line. did you check for leaks around the carb and intake ? with the engine running spray carb cleaner at base of carb and along the seam of the intake. did you check to see how strong the fuel pump is, if the surging is worse on an almost empty tank could be a sign of weak pump. eric j 1 Share this post Link to post Share on other sites
Walhonding520 25 #24 Posted August 13, 2017 How do I get the dang valve out of the bottom of the fuel tank. I want to clean it and the screen. Does it just pop out or do I have to unscrew it. I've been careful so far as to not damage it. Share this post Link to post Share on other sites
WVHillbilly520H 10,378 #25 Posted August 13, 2017 13 minutes ago, Walhonding520 said: How do I get the dang valve out of the bottom of the fuel tank. I want to clean it and the screen. Does it just pop out or do I have to unscrew it. I've been careful so far as to not damage it. Pry it out with needle nose pliers ,the rubber is the seal to the tank the barb on the valve holds it tight, it might not come out without ruining though, Jeff. 2 Share this post Link to post Share on other sites
