TRZ 3 #1 Posted July 19, 2017 So, as the title says my 14 hp onan isn't charging. I pulled the wire plug off the ref./rect. and checked the wire to the stator with multimeter. I get zero from 1-2 and .9 from 1-3 and zero from 2-3 I'm just assuming that means the stator is bad? Can I check the reg./rect. The same way to see if it is also bad. Next question would be where to find a new stator on-line I can't seem to find anything under these numbers? E140 OV-N/109648 Share this post Link to post Share on other sites
Duramax7man7 506 #2 Posted July 20, 2017 Do you have a shot of the tag on the engine? A photo of the engine would also help. Any numbers regarding the tractor model and serial number? Share this post Link to post Share on other sites
Duramax7man7 506 #3 Posted July 20, 2017 (edited) I'm not 100% positive that I you have the right model number... Could it be OnanE140 V-N (V= Vertical crank and N= Gasoline fuel.. Not sure what the O would be for unless it was accidentally doubled from the 0 in 140?) Check out page #5 here... http://www.twinslan.net/~n0nas/manuals/onan/965-0758 Onan E125H E140H Elite series Engine Service manual (01-1996).pdf And here is an Onan Manual with a parts list for an Onan Elite E140 that shows a stator. it might give you a lead or be the right one... Check it out... Stator number is: 191-1456-04 (Copy and Paste into a URL Address box at the top of an open internet window) file:///C:/Users/HTPC955/Downloads/i_2463_1_Onan%20E125HE140HOL13ZX390.pdf For Sale HERE on an auction site. Used one for $42.85 shipped from Illinois... Hope this helps! Edited July 20, 2017 by Mastiffman Share this post Link to post Share on other sites
TRZ 3 #4 Posted July 20, 2017 Thanks, I'll try and get you some pics and more info. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,852 #5 Posted July 20, 2017 Toro has the engine listed as E140V-N/10964B http://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/22-14o502-244-5-toro-244-5-yard-tractor-sn-2000001-2999999-1992/ The stator is on the 14HP ENGINE IGNITION ASSEMBLY page. Garry 1 Share this post Link to post Share on other sites
TRZ 3 #6 Posted July 20, 2017 So, Garry is correct with the model number. Now the used stator on eBay goes buy a totally different number than what the parts list shows which is NN1037. And the one Mastiff man shows is 191-1456-04. Different part or just different numbering system? Also does indeed the test I ran on the stator confirm that it is bad? Share this post Link to post Share on other sites
