Ffarmer 2 #1 Posted July 16, 2017 Just bought a C 165 and it has no power in the high range . What could be the problem ? Share this post Link to post Share on other sites
N3PUY 1,031 #2 Posted July 16, 2017 The engine looses power or the tractor won't move ??? Share this post Link to post Share on other sites
Ffarmer 2 #3 Posted July 16, 2017 Engine is great. Has no or little power in high range ,would not back up in trailer when I bought it . Worked ok in low range. Share this post Link to post Share on other sites
N3PUY 1,031 #4 Posted July 16, 2017 One of the axle hubs is loose. Put a crayon mark across both hub and axle, try to drive it in high range, see if the marks moved. Share this post Link to post Share on other sites
Ffarmer 2 #5 Posted July 16, 2017 Will do when I get it out of the garage. If that is the case , why is it OK in low range ? Share this post Link to post Share on other sites
N3PUY 1,031 #6 Posted July 16, 2017 lo range is turning much slower and not as easy to spin in the hub. Share this post Link to post Share on other sites
953 nut 64,093 #8 Posted July 16, 2017 Take a look at the drive belt, it may be the problem. 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,363 #9 Posted July 16, 2017 Welcome to Red Square , another guy from Richmond Va. ,watch out the addiction is catching , one is never enough. 1 Share this post Link to post Share on other sites
Big_Red_Fred 1,548 #10 Posted July 20, 2017 Tell me about it, Horse Fever Share this post Link to post Share on other sites
Ffarmer 2 #11 Posted July 21, 2017 Jacked it up this afternoon, right rear was at housing and would turn independently . Removed tire , removed hub, cleaned shaft and hub, and replaced all , setting the set bolts tight and jam nuts . Still have slippage and the belt is as tight as the one on my C125 . Did not check pulley on transmission . What next ? Share this post Link to post Share on other sites
cschannuth 3,819 #12 Posted July 21, 2017 Is the engine mounted on a cradle? Mine was and my belt was tight and it still slipped in higher gears. I replace the rubber mounts with solid mounts. Before I did that I jammed plywood shims between the cradle and cradle mount to immobilize the cradle to make sure that was my problem. Share this post Link to post Share on other sites
Ffarmer 2 #13 Posted July 21, 2017 Appears to be as mounted by Wheel Horse. Share this post Link to post Share on other sites
N3PUY 1,031 #14 Posted July 21, 2017 13 hours ago, Ffarmer said: Jacked it up this afternoon, right rear was at housing and would turn independently . Removed tire , removed hub, cleaned shaft and hub, and replaced all , setting the set bolts tight and jam nuts . Still have slippage and the belt is as tight as the one on my C125 . Did not check pulley on transmission . What next ? How about the other side? Share this post Link to post Share on other sites
