Scotty123
D200 fuel problem
Scotty123
Hello again
so now that I got my d200 wiring temperately figured out I moved on to the fuel system. The tractor has been sitting for about 3-4 years with gas in it so you can imagine the condition of the gas/water was in. I took the gas tank off and gave it a thorough cleaning the stuff coming out of it was more muddy water than it was gas. So after cleaning that out the best that I could I replaced the fuel lines and fuel   filter going up to the          Carburator but there was still no gas going to the carburator. So I sepected the fuel
pump to be the issue so I replaced the fuel pump and still nothing. At that point I thought that I would take the bowl off the carb to see what condition the carb was in and that turned into taking the carb off and giving it a deep clean witch I should have done in the beginning. But I still don't have any fuel going to the carburator so I don't know if I'm missing something simple like a ajustment screw on the            carburator or something so if one of you guys can think of something to try let me know. Thanks
benji756
are you getting fuel to the fuel pump?
N3PUY
shut off valve on?   plugged?
Scotty123
Getting fuel to the pump and the shutoff isn't closed only have to make that mistake once 😂 and it isn't clogged because I started to drain the old fuel from there. I poured alittle gas directly down the carb and it ran for about 5-10 seconds thinking that it might kick in the fuel pump but it didn't but on the other hand it ran good 😂
953 nut
:WRS:         If you have fuel flowing to the pump and the pump is not pumping it out I would suggest you check to be sure you have the "IN" and "OUT" lines hooked up properly.
pacer
Just go ahead and get an electric fuel pump and never look back. you'll thank yourself many times!
I got 4 of the D series and they all got electric pumps quickly....
  • Similar Content
    • BuffaloD200
      By BuffaloD200
      Finally getting around to working on my ark loader.  The previous owner said he thinks the problem is with the spool valve.
      As I've learned a bit more about hydraulics now, I'd like to get this all sorted out.
      I noticed the power beyond port is connected to the reservoir return.  Is that right?
      Anyone see anything blatantly incorrect?
    • BuffaloD200
      By BuffaloD200
      Hey all, I need to install a drive belt on my 75 D180 for my snowblower.  I've looked through a bunch of D-series owner's manuals, and none seem to mention replacement procedure.  The PTO pulley is fixed, save for engaging the PTO and there is minimal movement at the snowthrower pulley. There's no idler or tensioner as far as I can tell.  Do I have to remove the PTO pulley?  That seems to be a required service item.
      Same question for my 80 D200 as well really.
      Using the recommended 4L490W belt.
      Thanks
    • BuffaloD200
      By BuffaloD200
      Hey all, I'm doing my first fluid change on my new-to-me D200.  Refilling the transmission is proving to be quite the struggle.  I've attempted to fill the tranny through the dipstick with a variety of funnels, but the oil just spills over the top.  I may have managed to get a quart in.
      What am I missing?
    • cbj75
      By cbj75
      I have a 1975 D200 Wheel Horse with front mount dozer blade, package includes Wheel Horse Dump Trailer, 48" belly mower side discharge, Wheel Horse front and rear wheel weights, turning brakes, rear PTO and 3-point to 2" receiver attachment, and Brinley twin disc harrow. Rear luggage/rack carrier, All refurbished, sandblasted and painted Ford red in 2016. Lots of extra Wheel Horse parts included.
      Package price $3000.00.
      Bryce Johnson
      102 Anglers PT
      Mc Cormick SC 29835
      913-638-6788
      IMG_1962.HEIC IMG_1965.HEIC IMG_0279.HEIC
    • Crazy Old Red Horse
      By Crazy Old Red Horse
      Barn find 1975 D180. 608 original hours. Tractor and 48” belly mower look to be still in their original paint. Rear 60” finish mower looks like it has had one coat of new paint added at some point. Open to trades. Please email me with any questions or for additional photos. 35 miles north of Pittsbugh.
