tallen4392 71 #1 Posted July 11, 2017 I have been looking on here trying to get some info on what is best front tire for pushing. Snow ag or what else u goys use thanks Share this post Link to post Share on other sites
andyk 83 #2 Posted July 11, 2017 I've had good luck with stock turf tread, 2 Share this post Link to post Share on other sites
SylvanLakeWH 32,454 #3 Posted July 11, 2017 Me too...standard turfs, no chain on front...works fine for Michigan's "snow"... Share this post Link to post Share on other sites
bds1984 1,519 #4 Posted July 11, 2017 I have a dedicated plow tractor, 1988 520H, that has loaded ags on in reverse and with a 25 pound weight bolted to the wheel. It actually steers pretty good except when I'm trying to push a big pile of wet snow while turning or when it is super icy out! Share this post Link to post Share on other sites
wallfish 20,576 #5 Posted July 11, 2017 Wrap the center of the front tires with #40 roller chain. Put them on tight with the tire deflated, then air them up and steer like it's on rails. Buy a 10ft length and an extra master link for about $20 or so. Don't use bicycle chain because it tends to roll on the tire. 2 Share this post Link to post Share on other sites
DennisThornton 4,773 #6 Posted July 11, 2017 I try to plow before it gets over 6 inches so most of the time I'm OK but last winter we got 3ft overnight! I blew that because I would have never plowed it! Deeper than 6" makes me want to try John's suggestion about the roller chain. Share this post Link to post Share on other sites
tallen4392 71 #7 Posted July 11, 2017 i like the roller chain idea but worry about my asphalt driveway ( the chain cutting into it or leaving grooves in it ) 1 Share this post Link to post Share on other sites
KC9KAS 4,746 #8 Posted July 11, 2017 Some folks like the 3 rib tires for front shoe shoes. I would expect the only good tire on ice would be a tire with studs, or the roller chain trick. 1 Share this post Link to post Share on other sites
Deadguy 864 #9 Posted July 11, 2017 I have had good results with Carlisle X Tracs. Share this post Link to post Share on other sites
C-85 821 #10 Posted July 11, 2017 Before I learned about the roller chain trick or considered rib type tires I put Carlisle Snow Hog tires on my rig. I think these other snow tire solutions are as good or better than doing this, but this works pretty good in helping it to steer in snow. C-85 2 Share this post Link to post Share on other sites
tallen4392 71 #11 Posted July 11, 2017 Are those weights on the frt of your blade if so how do u raise it up Share this post Link to post Share on other sites
C-85 821 #12 Posted July 11, 2017 tallen4392 Are those weights on the frt of your blade if so how do u raise it up? Answer, nope if you look carefully these weights are independent of the blade and are on a weight carrier, held on by the front 'Tach a matic' point. Here's picture of the carrier - Thanks for asking C-85 2 Share this post Link to post Share on other sites
tallen4392 71 #13 Posted July 11, 2017 Thanks so those are adding weight to the front of your tractor good for pushing snow ?? Thanks Share this post Link to post Share on other sites
C-85 821 #14 Posted July 12, 2017 tallen4392 Thanks so those are adding weight to the front of your tractor good for pushing snow ?? Thanks Hi tallen4392, please forgive, I didn't provide all the info. I have a large weight box on the back of this tractor and with just an 8hp engine it was light in the front end, so I added a lot of weight to front of this tractor to help this. All this was to get better traction and steering. After I put the rear weight box on for traction, it created a light front end, so all the front weights were to counteract the weights on the back. This had nothing to do with the actual plow itself. Hope this helps. C-85 Share this post Link to post Share on other sites
tallen4392 71 #15 Posted July 12, 2017 Thanks so much for your time this is my first year using a c-81 to push snow so I was just wondering if it helped by adding the weight Share this post Link to post Share on other sites
TDF5G 2,074 #16 Posted July 12, 2017 17 hours ago, C-85 said: tallen4392 Are those weights on the frt of your blade if so how do u raise it up? Answer, nope if you look carefully these weights are independent of the blade and are on a weight carrier, held on by the front 'Tach a matic' point. Here's picture of the carrier - Thanks for asking C-85 How much do you have on the front? And the rear? Share this post Link to post Share on other sites
Paul Van Benschoten 18 #17 Posted July 12, 2017 21 hours ago, C-85 said: Before I learned about the roller chain trick or considered rib type tires I put Carlisle Snow Hog tires on my rig. I think these other snow tire solutions are as good or better than doing this, but this works pretty good in helping it to steer in snow. C-85 I use the same tires on the front for snow plowing. The front used to slide all over the place when the blade was angled. Share this post Link to post Share on other sites
tallen4392 71 #18 Posted July 12, 2017 That is what I am trying to prevent this winter no chains for the frt tires I have a fairly new asphalt driveway I know those chains would make a mess of it maybe tires like you have filled with washer fluid will be the way to go. Thanks again Share this post Link to post Share on other sites
