Big_Red_Fred 1,548 #1 Posted July 9, 2017 Hey Friends, i just purchased a C125 for 200.00, i had the key on removing fuel pump ( I didnt know i left it on ) and the coil started smoking, i pulled the positive cable off, I was wondering is it possible to convert the Old Cast Iron engines to electronic & if so where can i find these parts, wonder why the coil is mounted beside the Carb ? Strange place to put in case of fire Share this post Link to post Share on other sites
pfrederi 20,828 #2 Posted July 9, 2017 Kohler made an electronic ignition back in the late 60s early 70s called Breakerless. Worked great but when they fail now parts are hard to find and $$$$ . 1 Share this post Link to post Share on other sites
squonk 47,286 #3 Posted July 9, 2017 You smoked a $ 20 coil. Imagine how'd you feel with a $100 + module! 5 Share this post Link to post Share on other sites
953 nut 67,253 #4 Posted July 9, 2017 6 hours ago, Big_Red_Fred said: i had the key on removing fuel pump ( I didnt know i left it on ) and the coil started smoking You just learned not to walk off and leave the key on! Tuition; $ 20.00! Lesson learned, 4 Share this post Link to post Share on other sites
Big_Red_Fred 1,548 #5 Posted July 9, 2017 Was day dreaming i had a 953 Share this post Link to post Share on other sites
pfrederi 20,828 #6 Posted July 9, 2017 4 hours ago, squonk said: You smoked a $ 20 coil. Imagine how'd you feel with a $100 + module! If you can find a $100 trigger for a Kohler Breakerless system you are lucky 3 Share this post Link to post Share on other sites
