cleat 7,177 #1 Posted July 7, 2017 This was given to me by a coworker. It would not roll over so he put in a new starter and battery. Still no go so he gave up on it. Problem was carb leaked gas into cylinder effectively hydro locking it. Rebuilt carb and machine runs very well. Deck was very crooked so I leveled that and it should be ready to mow now. I think my wife will enjoy driving this. She can't reach the pedals on the 520's with Matt's kit installed. Paint is good on tractor. Deck needs some work to make it look pretty. Cleat 15 Share this post Link to post Share on other sites
Jerry77 1,218 #2 Posted July 7, 2017 Now that was a great deal - did it come with a deflector for the discharge chute? Good to know that your wife cuts grass - can't get mine near one... 3 Share this post Link to post Share on other sites
cleat 7,177 #3 Posted July 7, 2017 Came with the deflector. Looks like it was taken off when machine was new as it looks new. It also came with 2 large plastic pieces that get installed for mulching. Also came with all the manuals including a VHS tape (which I can't play as I don't have a VCR any more but I thing my mother in law does). My wife usually cuts the front lawn with a push mower and I cut the last 2 acres with a rider. She will like to ride I am sure. 2 Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #4 Posted July 7, 2017 Your co worker must be a nice guy , nice little rider does not look in bad shape. Share this post Link to post Share on other sites
cleat 7,177 #5 Posted July 7, 2017 He is a nice guy. Just retired actually. Here are the other parts. Also came with a little tool for removing and installing the deck lift assist spring. Cleat 1 Share this post Link to post Share on other sites
slammer302 2,156 #6 Posted July 8, 2017 Looks like it would be great for mowing duty. Share this post Link to post Share on other sites
cleat 7,177 #7 Posted July 8, 2017 (edited) Just washed up this little beast. Mowed the back yard with it and it did a good job. Edited July 8, 2017 by cleat 1 Share this post Link to post Share on other sites
cleat 7,177 #8 Posted December 21, 2017 (edited) Deck on this machine looked a little rough so I gave it some love. Nearly everything was bead blasted and painted. Deck had a few stress cracks that were welded up. Also one mounting pin was missing and had been replaced with a bolt. Proper pin is now welded into place. No rust holes, just some surface rust and minor pitting. Spindles were rebuilt with all new bearings. Idlers were repacked with grease and spin smoothly. Both belt tensioner bellcranks have new bushings installed and work smoothly. Front anti-scalp wheels have bronze bushings installed, and wheel bolts have been drilled then cross drilled and a grease fitting installed. Blades have been cleaned up, sharpened , balanced, and painted. I have new ones but these will work fine for now. New decals installed. Thanks Terry for the excellent decals as per usual. Here is what it looked like when I first pulled it. This is what it looks like now. Won't need it for a long time but at least it is ready. Just need to install it then level it and set the brake clearance. Edited December 21, 2017 by cleat 6 Share this post Link to post Share on other sites
WHX?? 51,441 #9 Posted December 21, 2017 Looks like new Cleat nice job My wife has the little brother to that tractor a 16-38HXL and she loves to cut all of our 2 acres with it. She is short but till can reach the pedals easily. Also have a nice little bagger for it too. Plenty of power and picks up nice with high lift blades. There were plastic things on the under side to make it a recycler deck but your doesn't have them. There might have been a blank off thingy for the discharge too. You plan to put on and use the deck wash fitting? I always though that was a good idea so ordered one for my other mower. I do go through bearings a lot though. Those style tractors are very abundant on CL around here and may upgrade her to a 44" if this one ever craps out but it just keeps going. Always though the transaxles would be problematic in these little gems but so far so good. Share this post Link to post Share on other sites
cleat 7,177 #10 Posted December 21, 2017 I have the 2 plastic inserts. Never used them yet. I find the hydro unit works great in forward but seems a little weak in reverse. I will check it out better this spring. I will not put the washout port back on. I once had a machine that had one and all it did was make a terrible mess where it was used and also took out the spindle bearings quite quickly. Cleat Share this post Link to post Share on other sites
cleat 7,177 #11 Posted January 2, 2018 (edited) I made a little collage to show the difference. Now if it would only warm up, melt the snow and grow grass then I could try it out. Cleat Edited January 2, 2018 by cleat 1 2 Share this post Link to post Share on other sites
ebinmaine 71,918 #12 Posted January 2, 2018 56 minutes ago, cleat said: Now if it would only warm up, melt the snow and grow grass When you figurin' on that. ... June. ..July. ...? Share this post Link to post Share on other sites
cleat 7,177 #13 Posted January 2, 2018 Likely........ Oh well. Share this post Link to post Share on other sites
ebinmaine 71,918 #14 Posted January 2, 2018 6 minutes ago, cleat said: Likely........ Oh well. You could mow snow. ... Wierder things have been done. Share this post Link to post Share on other sites
Jerry77 1,218 #15 Posted January 2, 2018 On 12/21/2017 at 11:22 AM, WHX14 said: You plan to put on and use the deck wash fitting? Never thought they would do any good, but it depends on the brand...i bought one made for a Husquavarna and it makes a spray about 70 degrees wide - does a really good job if you do it just after cutting.... Share this post Link to post Share on other sites
WHX?? 51,441 #16 Posted January 2, 2018 Agreed Jerry, you gotta do right after cutting and EVERY time. It starts to matt up and then its usually time to pull the deck , flip it and clean.... sharpen blades while your at it. They can be awful hard on spindles & bearings too but I hear tell Toro can be quite proud of theirs! 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,393 #17 Posted January 7, 2018 Cleat Did you know a pair of the blue Mastercraft sawhorses will lock together for storage and transportation? Took me a while to figure it out. Garry Share this post Link to post Share on other sites
