Gkiesel 0 #1 Posted July 6, 2017 Hello all. I have a 1969 Charger V -7 electric start that the motor is worn out. I know the faithful will probably boot me off the forum, but is it possible to mount a 7hp Honda motor? or something similiar? Not sure if it's a common bolt pattern or not with these old tractors. Any suggestions would be appreciated. Thanks, G Share this post Link to post Share on other sites
Racinbob 12,428 #2 Posted July 6, 2017 I doubt that the bolt pattern would match and there would be other things you'd have to deal with but it wouldn't be difficult nor the first Honda on a Wheel Horse. Share this post Link to post Share on other sites
Tuneup 1,452 #3 Posted July 6, 2017 They have put Hondas and Harbor Freight Predators on them. Saw someone out in Britain put a hit-n-miss on one so no booting will occur. You can be the first to put that Kawi 1100 on it but watch the wheelies - they starve for oil. Accept the challenge. Share this post Link to post Share on other sites
Gkiesel 0 #4 Posted July 6, 2017 Yes. The ZRX motor would do the trick. Is the old tecumseh bolt pattern the same as a briggs? or kohler? Just wondering. I guess I could make up a mounting plate. I just need the shaft to be long enough to get the drive pulley in the right spot below. Share this post Link to post Share on other sites
Howie 900 #5 Posted July 7, 2017 I am pretty sure the Tecumseh and Briggs have the same mounting pattern. Probably the Honda also have not had one of those in my hands to compare. Have switched Tecumseh to Briggs. Share this post Link to post Share on other sites
