valleyboy
valley boy
valleyboy
any problems replacing a K301 with a K321 on a c120 hydro ?
rmaynard
Can't think of any off the top of my head.
953 nut
:WRS:          Should be a direct bolt up if the oil pans are the same. If not, and they are both big blocks then you can leave the 301 pan on the C120 and bolt the block to it.
ztnoo
valleyboy,
I have a suggestion in regards to your posting habits on various topics.
In every topic you have ever started here on RS, save one, you are using you user name as the subject line, although you are posting in various forums on different subjects.
Doing so only impedes and confuses what you are attempting to ask and find a solution for.
I would say your posts will be much more quickly and effectively answered if you make reference to your specific problem or question in your subject line, rather than continuing to use your user name in the subject line.
If you don't, I can envision multiple topics (maybe eventually dozens) with exactly the same subject line going forward, with absolutely no way for anyone, or yourself, to clearly delineate what you might be describing short of actually opening each individual post.
That's very inefficient, not to mention confusing.
Just a suggestion and food for thought before posting a new future topic.
Regards,
Steve
Edited by ztnoo
  • Like 6
  • Similar Content
    • Rob R
      By Rob R
      Hi Guys, got a K321 14HP Kohler in house with all the electrical components removed. I cleaned and aligned the points, added a 12v (resistor coil) positive 12V battery feed to positive terminal, ran a line from the negative side of the coil to the points. I know I have to add a condenser also to the negative side. My question is does location of the condenser matter i.e. next to the coil or is closer to the points better. Thanks Rob
    • Charles99
      By Charles99
      ok I'm new to these and first time really working on small engines. i have a k301 engine. i ordered the tune up kit with new coil, condenser, and points. after installed it won't fire. it turns over that's it. I made sure everything is grounded and the points have proper gap . 20. i have voltage at the coil i have spark at the points. i took the plug out that has spark. I'm not sure what else to do I'm about to start putting old parts back on and see if that changes anything. it did run before hand pretty well actually besides an occasion sputter or hiccup.
    • BrianKoch
      By BrianKoch
      Gentlemen,
      I am in need of help. While doing yard work with my K301 powered ‘68 Charger 12 it suddenly came to a stop and won’t start again.
      My troubleshooting so far:
      Fuel:
      • stabil/87 and clean
      • good flow before and after pump
      • carb clean, recently rebuilt, float level correctly set
      Compression:
      •good? - blows finger off spark plug hole
      •good turnover but doesn’t fire off
      •piston and cylinders move freely
      •valve lash set .008 intake .018 exhaust
      •breather assembly correct and recently serviced with new gaskets and filter
      •head gasket not broken, head bolts tight, some carbon on head
      Spark:
      •no spark
      •all electrical/ignition components were replaced 1 year ago except voltage regulator
      •no loose connections, no grounding connections
      •inspected and applied graphite to starter shaft
      •changed plug
      •12v to coil good
      •cleaned points, points wire has continuity
      •condenser ground good
      •swapped battery, points and wire, plug and wire, coil, and condenser from running K301 (‘69 Charger 12)
      •points push rod does push out when turning engine over by hand, but unable to get points timed using multimeter method and timing mark on flywheel
      What else should I check/do?
    • Jeff-C175
    • PWL216
      By PWL216
      Hi. I have a C121 which starts right up but lacks power. A compression check indicated 30lbs of pressure. I took the head off hoping maybe it’s just a gasket, but I think the cylinder needs to be honed or bored out. Based on the attached pics, is this block still good and would honing fix it?
