12 hp Kohler 1,020 #1 Posted June 30, 2017 I bought a snow plow for one of my wheel horses at the big show but I need a lift arm for it, I would like to make one but I have no clue of dimensions and couldn't find them on the internet but I figured somebody on here would no them or have a link or know what they are. Any help would be greatly appreciated. Here is a picture of what the bracket looks like. Share this post Link to post Share on other sites
R. L. Addison 299 #2 Posted June 30, 2017 Is going to be manually or hyd. lifted? If hyd., then I would want it to "float". If manual lift, the lift handle will move as the terrain changes that you are working. If hyd. lift the op[en centered valve will let it "float". Will bring one in and measure it later this evening. Mine "floats" by the chain between rocker shaft & lift arm. Share this post Link to post Share on other sites
12 hp Kohler 1,020 #3 Posted June 30, 2017 It is for a manual lift I am putting the plow on a 753. Thank you for the help. Share this post Link to post Share on other sites
elcamino/wheelhorse 9,362 #4 Posted June 30, 2017 There is a thread on that some where. I think the lever is 12 " over all in length . The pins are 11 inches center to center and the width is ether 1 inch or 1 1/2 inches and the lever is 1/4 inch thick. 2 Share this post Link to post Share on other sites
12 hp Kohler 1,020 #5 Posted June 30, 2017 Thank you very much, I will start with that Share this post Link to post Share on other sites
Tankman 3,523 #6 Posted July 2, 2017 Perhaps this'll work. I've made many lift arms. 1 Share this post Link to post Share on other sites
12 hp Kohler 1,020 #7 Posted July 2, 2017 That helps a lot thank you 1 Share this post Link to post Share on other sites
